Header Bolts & Anti-Seize
Discussion in 'Technical' started by mojo, Mar 4, 2013.
  1. baddad457
    :D You're just a "touchy -feely" kinda guy :Handshake
  2. simple man
    simple man Member
    Bunnell,Florida
    Don't feel bad, I have it in very small tubes and still manage to get it where it doesn't belong! :cry:
  3. 71gold
    point is...if you put it on anything it will be on everything...:yup:
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    because we're all about the sharing around here.. I have two words for you.
    SHOP RAG. ;)
  5. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    ...refrigerator door, telephone, forehead...
  6. 71gold
    that's the last place I want it...:rolleyes:
  7. baddad457
    :D I got your meaning the first time ;) Just pokin fun at something that I've done as well. Just when you think you got it all wiped up, and clean, some how another smear suddenly appears. :D Same thing happens after I've greased something.
  8. Bryant
    i have found that using the fiber type gaskets is what causes header bolts to loosen up. it will shrink and lessen the load on the header bolts allowing them to back out. lately ive been using the mr. gasket mls gaskets and have never had a bolt back out and when ive gone and rechecked them they are all still tight. before those were available i was using the earls pressure seal gaskets which used an aluminum frame with a graphite seal with the same results. the mls gaskets are reusable and easier than dealing with the graphite.
