Header collector too close to the ground...
Discussion in 'Technical' started by mashori, Jun 26, 2012.
  1. baddad457
    Y'all are stuck on one brand/type here, all he needs to use is the wide band exhaust clamps, like they use on the big trucks. Nothing hangs down on these, unless you position the bolt wedges in the 6 o'clock position.
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Put some zoomie headers on, no more ground clearance issues.:D
  3. olerodder
    olerodder Member
    NorCal
  4. olerodder
    olerodder Member
    NorCal
    I guess I'd never seen these before...................they are cheap and if you can find one with your OD pipe size would be worth trying;
    http://www.ryderfleetproducts.com/r...o;jsessionid=C85E40B5018E3F85A1AE7B775E98CB01
  5. blugene
    I see what you mean :)..
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    which are the shorty headers that people have tried out?
  7. baddad457
    Yea, that's it. Summit lists them in the smaller sizes he needs. Granted, he's only going to gain about a half inch clearance by loosing the collector flanges, if he really wants more then custom headers are where he needs to go. Pretty sure he needs to stay away from shorty's with the HP he's talking about.
  8. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I was joking when I said use a Windsor block, but that extra height really does help with header clearance under the car, so it occurred to me... How 'bout raising the engine a little bit?
  9. darren
    Then your messin with driveshaft angles....also he doesnt want that engine weight higher in the chassis for road racing.
  10. darren
  11. olerodder
    olerodder Member
    NorCal
    With this suspension...........you basically stay stock................and have the ability to adjust the ride height.................and inch or two could make all of the difference plus this would really handle a lot better than your current stock suspension.........................just a thought.
    http://www.globalwest.net/comst-6770d.html
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    the suspension I have right now is a double adjustable coil-over conversion. You actually make a good point because my car has sagged unfortunately due to me installing the bolts improperly. Maybe fixing that will help quite a bit. thanks for pointing that out.
    you can see the sag here
  13. olerodder
    olerodder Member
    NorCal
    I didn't realize what your suspension was.
    Maybe it's just the picture, but it looks like the shock pedestals are bent?
    I'm pretty sure you can adjust it enough to keep the header flanges from hitting.
  14. Dave B
    What did they say about those bending like that? Did VariShock give you a reason?
    I ran long tube Headmans for years on another car, they really hung low...I'm more than happy with the Doug Thorley shorties, I'll be ordering another set for my other car.
  15. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    any chance you might have a pic from under the car, like a profile shot to see how low they are?
    As for the shocks, they were very helpful, they sent me a free set that apparently would solve the problem of over-tightening. They think I over-tightened the ears which is possible. The instructions are confusing and detailed and I tried my best to follow them.
