Headers are in
Discussion in 'General Maverick/Comet' started by x72COMETx, Sep 18, 2014.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    I finally got my headers in, took alot of tweaking. Also i have a question about the trans mount, is their a difference between the I6 and V8 ones thanks
  2. x72COMETx
    x72COMETx Member
    Vallejo CA
    Heres a pic of were my headers point
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Yes the v8 cross member has 2 bends in it where the i6 doesn't. If you look under your car you'll see another set of hole on the driver's side above where the i6 cross member bolts to.
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    Ya i remember seeing those holes when i had the trans mount off.
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Can I ask, what happened to the lip where your floor meets the sill? That is all bent up.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Everyone time i get under their i ask myself that, idk they were like that when i got the car
  7. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Someone probably tried to jack the car from the pinch weld.
  8. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Those look just like my headers. Are they the summit long tubes?
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    Yes their the $129 set
  10. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Yup same ones I have. Even got mine to work with gt40p heads.....had to clearance tubes 6 and 7 but nothing other then that.
