Headers with GT40P heads
Discussion in 'Technical' started by maver88, Jun 24, 2011.
  1. BamaV8MavMan
    BamaV8MavMan Member
    Attalla, AL
    1972 Ford Maverick 2 door V8
    thanks for the info! yes please post photos, thanks
  2. maver88
    maver88 Nick Taurone
    Russellville, AR
    1972 Ford Maverick 2-door & 1996 Ford F150 4wd w/ 429ci/granny low 4spd
    I kinda got ahead of myself when I said Denso makes a short plug, they are listed as a short style but I compared them to some normal NGKs and they're not really shorter.
    Ohh I forgot to mention that I had to use 4x studs & longer bolts with the spacer + two gaskets
    I got stainless hardware from my near by ace hardware store
    but here are the pics 20150610_182506.jpg 20150610_182557.jpg 20150610_182611.jpg
    The one tube that's really flat on the third picture is because I didn't realize that it was going to interfere with the steering box until it was in the car. Tried to fix it, ripped a hole in it, and had to pull it out to patch it anyway lol
  3. scooper77515
    I used Accel P-526S plugs which are a good bit shorter than stock plugs. BUT they were $13 EACH!!!
  4. maver88
    Russellville, AR
    Yeah I'm waiting to buy a set till after I get my timing & carb set so I don't ruin them. I couldn't believe $13 either:eek3:
  5. BamaV8MavMan
    BamaV8MavMan Member
    Attalla, AL
    Maver88,
    Where did you find the 3/8" header flange to use as a spacer?
  6. BamaV8MavMan
    BamaV8MavMan Member
    Attalla, AL
    Is there another plug company that makes shortys that cross reference?
  7. maver88
    Russellville, AR
    I cut the tubes off the stock explorer manifold and used it
  8. BamaV8MavMan
    BamaV8MavMan Member
    Attalla, AL
    I was able to order a 3/8" flange from summit that will work fine. Thanks
