headers
Discussion in 'Technical' started by wolfheads, Apr 30, 2015.
  1. baddad457
    Yea, the Tri-Y's fit like a glove in an 89 with a 157 tooth bell. Never tried the 88400's but I know others have and said they work too. The tri-Y's need to be tweaked to clear a 164 tooth bell
    BBMS18 likes this.
  2. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I’m working on a 2000 4x4 V8 and I’m afraid my only options are factory manifolds or those $700 Explorer headers.
  3. baddad457
    Check on either therangerstation.com or rangerpowersports.com on their V8 forums. If anyone's tried them, it would be someone there. There's dedicated threads for headers on both sites
  4. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    I have the 84400s on a similar setup as yours. 302 with column shifter c4 and p/s. The header itself fit fine and looked as if everything would fit with no clearance issues. The problem is the exhaust pipe coming down from the reducer. My exhaust installer even used 2" pipe in that area but it still had to be dimpled for the pitman arm. After the initial installation the left steering was affected enough that I took it back to the shop for the dimple. Also if you buy the painted ones, high temp exhaust paint will not stick to the primer. I tried scuffing mine and then painting but it flaked badly after they got hot. Passenger side fit with no problems.
  5. Bad1974maverick
    Bad1974maverick Member
    Columbus Ohio
    1974 Maverick Grabber
    Thanks for the info. I have to take the heads off to do gaskets any way and the exhaust pipe is all new from the manifold to the tips. So if it has clearance issues, then would be the time dimple the pipe.
  6. HadaGrabberonce
    Talcott WV
    I meant to say 88400s not 84400s. Curious though that some people have had no clearance problems with these headers and the pitman arm. Possibly could have been the installer I used. I had a complete dual exhaust system installed and overall I am pleased with the result as far as the sound and the look but the performance gain was a little disappointing.
  7. mojo
    I don't know of anyone w/ these headers who have not had issue, pittman hitting collector!
  8. Bad1974maverick
    Columbus Ohio
    So the Hedman 88400 shorty's and go?
  9. Craig Selvey
    I don't know the "number" off hand, but that sounds about right. I wrote a tech article about it on here somewhere.
    Earl Branham and BBMS18 like this.
  10. Craig Selvey
    In the tech article I write about modifications to the driver's side collector.
    BBMS18 likes this.
  11. Bad1974maverick
    Columbus Ohio
  12. dyent
    dyent Member
    vancouver bc
    I wonder how those Headers would work on a 351W swap?
    David
  13. BBMS18
    BBMS18 Member
    75 Comet
    Craig, thank you very much. That’s the best information I’ve seen on headers for the Maverick/Comet.
    Earl Branham and Craig Selvey like this.
  14. Craig Selvey
    I will add this: Doug Thorleys fit a lot better.
    BBMS18 likes this.
  15. HadaGrabberonce
    Talcott WV
    The Hedmans are reasonably priced but I wish that I had seen that article before installation. I should have done more research. That is a much better solution than dimpling. Too bad Hedman will not make the mod necessary for these to fit our cars.
    mojo likes this.
