Headers?
Discussion in 'Technical' started by Bad1974maverick, Oct 22, 2019.
  1. Bad1974maverick
    Bad1974maverick Member
    Columbus Ohio
    1974 Maverick Grabber
  2. Bad1974maverick
    Columbus Ohio
    I found Headman 88400 shorty's. Guy at Headman said they won't clear the column shift C4. A lot of headers are almost what I paid for the engine. Think I'm Stuck with the stock manifolds.
  3. mojo
    Ok on won't clear column shifts; I do have floor shift. Ceramic coated ones ain't cheap; none coated reasonable cost, and you haven't factored cost of custom muff shop expense. Stock header work well on stock motor. My car came w/ long tubes so I replace w/ aftermarket headers.
  4. Bad1974maverick
    Columbus Ohio
    My problem is my stock manifolds are emissions manifolds. I don't mind non ceramic or standard headers as I don't drive it in bad weather anyway so I don't think it will be too much of a problem. Problem is seems no one makes a column shift shorty header that bolts to factory exhaust locations and I don't want to cut up a new exhaust system. You'd think with as much as Mavericks are modified this product would be a little more out there.
  5. Krazy Comet
    Short answer not enough demand. There are probably a larger number of Fox 5.0 Stangs in Columbus than Mavericks in all the US combined.
    mojo likes this.
  6. Bad1974maverick
    Columbus Ohio
    Well even though I take that as a figure of speech there is some truth to it. There are a few Mavericks around but you don't see very many Fox bodies either, not in Columbus and the ones you do see are usually rusted out and not 5.0s. As a Fox Body owner and former owner of 3 others, I see where you're coming from.
    This is my 87 with 45K original on her. like all good fords, keep the bitch floored!
  7. 71gold
    you could get a set of non California compliance stock manifolds and get the same results, lot less problems.
  8. Bad1974maverick
    Columbus Ohio
    That was pretty much what I was going for. I prefer headers for better flow and to a lesser extent sound but still, as many column shift v8 C4 mavericks are out there and no one has a shorty header?
    71gold likes this.
  9. Craig Selvey
    Drop bracket not required on any shorty header
    Get the Doug Thorley headers. They are a shorty. I have them on my car. Easy to install. Will work with a column shift.
    Hedman shorties will work with a column shift as well. Somewhere on here is an article I wrote about the Hedman shorties.
    My Doug Thorley header install:
    http://mmb.maverick.to/threads/doug-thorley-headers-installed.32902/
    Crazy Larry likes this.
  10. Bad1974maverick
    Columbus Ohio
    Thanks Craig. I found Headman 88400 shorty's and those should work? I really like the doug thorleys but on a 302 with just a carb and intake they are a bit pricey.
    Separate topic, when I bought that hood off of you around 12 or so years ago you were fooling with some headers and moving the engine around, was that when you were modifying the Thorley headers from your article? I remember them fighting you a bit and you seemed to have a devil of a time because of those heads. Just curious.
  11. Craig Selvey
    If it was the orange car then it was the Doug Thorley headers. The only problem I had with them was the spark plug angle of the aftermarket heads. Install was pretty simple typical of any header install.
  12. Krazy Comet
    If your transmission has this "ear" you'll probably have to chop it off.
    A good exhaust shop can maybe work around it, I took the more direct approach.
  13. Bad1974maverick
    Columbus Ohio
    What headers are you using?
  14. Bad1974maverick
    Columbus Ohio
    Yea it was the orange one. will the Headman 88400 shorty headers fit?
  15. Krazy Comet
    Doug Thorley.
