Headers
Discussion in 'Technical' started by n2omaverick, Dec 16, 2003.
  1. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    oh and btw.........yes they are prefabbed for the mavs
  2. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Heres mine with a full ,useable interior.
  3. M.A.V.
    Macon,Georgia
    removable cross bar...:bananaman
  4. M.A.V.
    Macon,Georgia
    :rolleyes: Pic will help
  5. M.A.V.
    Macon,Georgia
    easy access side bars;)
  6. n2omaverick
    n2omaverick Member
    Delaware
    Car weight
    I have been asked a few times about how light my vehicle is, I did some research on this and this is what I came up with 1n 1972 the v8 maverick was 2550 with the v8 and power steering, Mine originally had the the 6 in it but I doubt that makes a weight difference now!
    I do not have power steering wich I figure is 50#s lost
    they came with steel wheels to the tune of 31 pounds each my welds on the front only weigh6 pounds (15x3.5) and rear ones weigh about 12 pounds each for a nother total loss of about 80 pounds. the bumpers in steel were about 35 each and the glass ones that I run had a packaged weight of 7 pounds each for a nother net loss of 50 pounds. The v8 maverick also had An iron intake manifold atabout 45 pounds and the vic jr is only 25 for a nother net loss of 20 pounds and then the stock cast iron heads weigh 56 pounds each and the alluminum heads weigh only 35 pounds each for yet another net loss of 40 pounds my hood weighs about 15 pounds and the factory one is like 45 for a total loss of roughly 270 pounds I took mine to the dump and pulled on the scales and the car weighed just shy of 2300 pounds with a full tank of gas and full interior. I had a guy at the track tell me his was 2800 dry without him in it and I told him he was nuts. How much do your guys cars weigh, I once read an artical that compared the weight of these cars to the falcon of the mid 60s at 2600 pounds . SO all of this being said How much do you guys weigh????? I doubt that dot registered scales are that far off do you??????
    Dave
  7. Mavaholic
    OK, going by your list, I should be equal with the following exceptions. I still have:
    Steel wheels 80lb
    Stock bumpers 50lb
    Stock hood 30 lbs
    I also am running a 9" which I believe is around 80 lbs more. But, I'm running a 4 speed which should be lighter than your automatic. My car weighs 3010 lbs on a Certified Cat scale with a full tank of gas.
  8. Purple70
    Purple70 Member
    Dayton Ohio
    that 2485 sounds SUPER LIGHT!! my uncles race maverick, has glass fenders, hood, lexan windows, 2x3 backhalf job and alum floor, and only 1 racing bucket weighs in at around 2600#'s my car with a full interior and a full tank of gas was around 2900 w/o me in it,,
  9. courier11sec
    courier11sec Member
    Tucson, AZ
    Very nice!
    Grabber-
    Thanks.
    You too 5946.
    :D
    That looks great M.A.V.
  10. n2omaverick
    n2omaverick Member
    Delaware
    How are you picking up 500 pounds I can see adding 100 pounds of roll bar or so but 500 pounds what year vehicle did they add steel after 72? there has to an answer to this, once I did the research the math worked out think about how much lighter headers are than manifolds and how heavy a stock 12" torque converter is compaired to the 8" that I run, I also run the 9" rear but have a light weight spool I know 3rd members weigh roughly 20 pounds different between a 8" and a 9" but 80 pounds how is this possible when axles are the same and so are axle tubes??? I have a mini starter as well (minimal diff) All these things add up. I have talked to some maverick guys that admit to being @2500 like me and yet others that say they are in the 2800# range but now a 3100 pound maverick, Something isnt right, I checked my book again and curb weight in 1972 with a v8 and ps was 2550, where are you picking up the weight at????
  11. Mavaholic
    I'm sure the only real way to compare is if everybody used the same scale. Supposedly, these Cat scales are guaranteed in writting to be with 1 pound, but who knows for sure. If DOT scales are run anything like typical a government department, I wouldn't put much faith in the accuracy of their data. Maverick doors got lighter, I believe it was after 73, when Ford removed the reinforcement beems out of them. If you doors are original, they will be much heavier. Just for comparison, you might want to find a truck stop with a Cat scale and give them a try.
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I know my old heap is pretty gutted: no front bumper(right now) no interior, aluminum heads, mini-starter, lightweight internals in the rear end, and so on, and it weighs 2635 w/o me in it. And that was put on a 4 tire scale, each wheel independant. The guy who scaled mine out does almost all the outlaw, true and limited street cars around here.
    Thats amazing that you got that light, I know Ivy Collins ole mav. is pretty light to but I think he has a aluminum dash and all sorts of stuff done to his to save weight.
    Thats great that you got it that light!
  13. n2omaverick
    n2omaverick Member
    Delaware
    weight
    I just found some articles on fordmaverick.com that show that by 1974 the v8 bucket seat (ps and ac) maverick grabber was 2900 pounds, and that article states a 2626 pound weight (75 pounds higher than I had read in the ford article) for a 72 Either way your roughly taking 300 pounds out with a glass hood , bumpers, aluminum wheels, heads and intake, not to mention headers vs manifolds this puts you if you have a pre 73 at 2325 dry by my calculations, I have a old 5.0 buddy that uses the digital 4 wheel scales to tune his Dragradial 90 5.0 I am going to call him today and see if he cant bring them over, My curiosity is peaking. It would explain why I havent gone as fast as I think I should have if its a couple hundred pounds heavier than I think
    Dave
  14. n2omaverick
    n2omaverick Member
    Delaware
    weight
    I just came across this article this is for a 71 6 cyl. I will post data for 8 cyl 72 grabber in a minute, its like 2600 with v8 buckets (buckets are 50#s more than bench acording to one article)
    200 CID Six Engine
    SelectShift Transmission
    Semi-Automatic w/170 CID only
    SelectAire Conditioner
    Tinted Glass
    Day/Night inside rearview mirror
    AM Radio
    Interior Trim Options:
    Blazer Stripe Seat Trim (w/Accent Group only)
    Vinyl seat trim
    Group Options:
    Grabber Option: Click here
    Accent Group: Bright Drip Rail Moldings and Window Frames,
    6.45-14 BSW tires, Wheel Covers, Color-Keyed Carpeting
    Tires & Wheels:
    6.45-14 BSW Tires
    6.45-14 WSW Tires
    6.00-13 WSW Tires
    Wheel Covers w/14" Wheels only
    Colors: Anti-Establish Mint, Hulla Blue, Original Cinnamon, Freudian Gilt,
    Thanks Vermillion, Candyapple Red, Black Jade, Champagne Gold,
    Gulfstream Aqua, Meadowlark Yellow, Brittany Blue, Lime Gold,
    Dresden Blue, Raven Black, Wimbledon White
    Click here for Grabber Colors added later in 1970
    Interior Colors:
    Nugget, red, blue or white
    Wheelbase 2-Door 103.0
    Curb Weight 2-Door 2501 lb
  15. n2omaverick
    n2omaverick Member
    Delaware
    weight
    fully loaded (every option max vehicle curb weight 1972)
    Optional Features: 2 and 4-Door Sedans Top of 1972
    Luxury Decor Option - Exterior
    Raised-grain vinyl roof
    Bright bodyside and wheel lip moldings with color-keyed grained inserts
    Front and rear bumper guards with color keyed rubber inserts
    Bright belt molding, window frames and drip moldings
    Bright pillar appliqué with color-keyed insert (4-door only)
    C78x14 WSW tires
    Color keyed wheel covers
    Outside remote control left hand mirror
    Chrome-plated grille with road lamp inserts
    Deluxe gas cap
    Luxury Decor Option - Interior
    Tawny tan color scheme
    Integral front door armrest door pulls
    Unique reclining front bucket seats
    super-soft all-vinyl seat trim
    Cut-pile carpeting
    Padded door trim panels, cigar lighter, inside day/night mirror
    Color-keyed instrument panel with wood grain appliqué
    Deluxe color-keyed two-spoke steering wheel
    Padded and carpeted utility shelf
    Deluxe color-keyed seat belts
    Exterior Colors for LDO option
    Pearl White w/White,Brown,Copper Odense Grain Vinyl Roof
    Med. Brown Met. w/White,Brown Odense Grain Vinyl Roof
    Med. Yellow Gold w/White Odense Grain Vinyl Roof
    Light Blue w/Blue Odense Grain Vinyl Roof
    Med. Green Met. w/Green Odense Grain Vinyl Roof
    Dk. Green Met. w/White,Green Odense Grain Vinyl Roof
    Tan w/White,Brown Odense Grain Vinyl Roof
    Med. Lime Met. w/White,Green Odense Grain Vinyl Roof(2 Door only)
    Med Brt. Yellow w/Brown Odense Grain Vinyl Roof(2 Door only)
    Engines:
    6-cyl. 170-cu. in. (This engine available with manual transmission only)
    6-cyl. 200-cu. in. Single Barrel Carb
    6-cyl. 250-cu. in. Single Barrel Carb
    V-8. 302-cu. in. 2-Barrel Carb (3-speed manual trans not available in California)
    Transmissions:
    Column-mounted - 3-speed, fully synchronized manual(Standard)
    SelectShift - (200 & 250 Six and 302 V-8 Engines)(Required on 250 Six)
    Floor shift available w/3-speed manual and 200 Six and 302 V-8.
    Floor Shift available on models equipped with SelectShift and bucket seats.
    Axles Ratios: Top of 1972
    3.00 Axle Ratio
    Other Options:
    200 CID Six Engine
    250 CID Six Engine
    302 CID V-8 Engine
    SelectShift Cruise-O-Matic Transmission
    Floor Shift on 3-Speed Manual
    Rear Window Defogger
    Tinted Glass
    Power Steering
    Deluxe Seat Belts
    Bumper Guards
    Door edge Guards
    Heavy Duty Battery
    Heavy Duty Suspension
    Electric Clock
    Lockable stowage consolette
    Tu-tone Paint
    Vinyl roof
    Group Options:
    Convenience Group: Cigarette Lighter, Color-Keyed LH Remote
    control Racing Mirror, Day/Night Inside Rearview Mirror
    Protection Group: Body molding with black vinyl insert and front
    and rear bumper guards.
    Tires:
    6.45-14 WSW bias Tires
    C78-14 BSW bias Tires
    C78-14 WSW bias Tires
    DR78x14 WSW Radial Steel Belt Tires
    D70-14 WSW Wide Oval belted tires
    Colors:
    Interior:
    Exterior:
    Med. Brt. Yellow w/Brown Odense Grain Vinyl Roof(2 Door only)
    Color Glow Paint available in either Ivy or Gold
    Curb Weight 2-Door 2681 LB
    Curb Weight 2-Door 2736 LB (Grabber)
