Headlight switch
Discussion in 'New Members Forum' started by LowCost, Jun 25, 2017.
  1. LowCost
    LowCost Member
    mount vernon illinois
    72 grabber
    OK so I have a dilemma. Tail lights work and signals work but I can't get my headlights to turn on. I already have replaced the switch and all fuses in the fuse box and still no head lights. I have come to the conclusion that the wiring is shot and would like to know what terminal on the switch goes to the lights so I can direct wire some new connections
  2. yellow75
    Tillamook Oregon
    I would check the high/low dimmer switch on the floor and make sure the headlight bulbs are good
  3. LowCost
    LowCost Member
    72 grabber
    OK I checked it and replaced it but still no headlights. Bulbs are still good
  4. Krazy Comet
  5. 71gold
    check the...bulkhead plug...on the firewall (just above the master cyl.)
  6. Krazy Comet
    Possible but would require both the Hi & Lo connections to be defective... OP says he has no headlights and has checked the Hi/Lo and headlight sw...... With neither operating problem is likely between the H/L sw and dimmer sw...
  7. 71gold
    when you checked it, did it have power going to it?
  8. LowCost
    LowCost Member
    72 grabber
    Sorry for the late reply, but yes I checked it with my meter, and what seemed to be the problem was a short on the passenger side wiring harness. So I cut out all the wiring for that side and ran new wiring and now problem solved .
  9. 71gold
  10. Paul Masson
    1971 Grabber
    Glad you figured it out! :Welcome: from Atlantic Canada!
