Headliner woes
Discussion in 'Cosmetic' started by blugene, Nov 2, 2009.
  1. blugene
    Be careful.
    Thanks for the tip. I actualy forgot.
  2. Craig Selvey
    Here is how you do it: (2) small screwdrivers....one on each long side of the trim, right in the center. Pry gently at the same time on both screwdrivers.
  3. mean_maverick
    maybe one of my door panel tools might work good for that as well...
  4. blugene
    LOL! I'm so excited about getting the liner and the glass in... I forgot I need to get the dash in before the glass :slap:
  5. Mavman72
    Cover the dash with some heavy masking paper before you install the windshield.
    Wouldnt want you to scratch that fine finish you put on it.
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
  7. blugene
    Hey, once it's up, if I have to poke holes and i'm not sure, it don't need it lol.
  8. mean_maverick
    i completely agree with that theory.... on everything in life LOL
  9. blugene
    :rofl2:... :tiphat:
  10. mean_maverick
    tried to get a few of those little plastic peices out today and EVERY single one broke as soon as i touched it. i say to hell with them and install the headliner, and cover the hole where that peice goes :yup:
  11. Earl Branham
    Lugoff, SC
    Gene; if you can find a couple more of the plastic clips, you can drill a small hole in the B pillar and put them up there, to hide and hold the headliner. Mine came down in that place, and the clips will hold it better.
  12. blugene
    The same ones? Looks like I might have to look for an alternative. There is already a hole so...
  13. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Thanks! Mine must have broke off long ago...
    Russ
  14. Fastkarz
    Fastkarz Member
    Northern NJ
    1972 Maverick Grabber 347/AOD/4.11
    Headliner Advice
    Just did the headliner in my 74.
    Put the metal rods in first (angled up, they don't rotate, go ahead and ask how I know)
    Use a LITTLE adhesive on the outer lip of the rear window. Center the headliner from side to side. Then stretch a little in the center of the rear window and use some spring loaded clothes pins to hold the headiner in place. Takes about 30 clothes pins.
    Wrap back of C pillar into rear window lip and repeat (5 clothes pins per side)
    Next do the rear vent windows. Don't fold over too much material or it will show past the window seal (again, go ahead and ask how I know) about 10 clothes pins per side
    Just fold the material over at the top of the B pillar on itself. The seal from the quarter window and the door seal will hold it in place. I didn't use adhesive in this area.
    Repeat for the front windshield opening. 30 clothespins
    At this point it should be tight, stretch into the doors, repeat the adhesive and clothes pins
    I let mine set up overnight. Then installed rear window, quarter window seals, windshield, door seals last.
    They are right, had a hard time finding the hole for the dome light DOH.
    The hairdryer didn't do much for me and I had two wrinkles that have me SOOOO :mad:
    Good luck
    Sean
    Good luck
  15. blugene
    Great info Sean! Thanks! :thumbs2:
