Heater Box 72 Grabber Heat ONLY. NO A/C.
Discussion in 'Technical' started by Slider28, Oct 27, 2018.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    I am going to try to get all the leaves out of my heater box and put a Cowl cover on the outside. How hard is it to get all the leaves out of the heater vents? I tried with the blower motor, but still more and more come out. SO I figured I would just do a proper clean.. I am putting new carpet in and I don't want all that dirt and leaves on my new carpet.
    Thanks!
    Chaz..
  2. 71gold
    pull the box...:yup:
  3. Slider28
    Slider28 Member
    San Antonio, Texas
    Is it a big job to pull the box? 1 hour? 6 hours?
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    More like 1 - 6 days.
  5. 71gold
    heat only...30 mins...:huh:
    heater hoses and a couple of bolts under the hood, the rest under the dash.
    then you can stick your hand up in the cowl and get the leaves and junk out of it.
    Slider28 likes this.
  6. Slider28
    Slider28 Member
    San Antonio, Texas
    Guess I have something to work on tomorrow. The cowl has a small hole in it.. I should be able to fix that from inside when I take out the heater box shouldn't I?
  7. 71gold
    do you have a pic of the hole?
  8. Slider28
    Slider28 Member
    San Antonio, Texas
    Not yet, I need to remove the heater box first, I am going to do that this afternoon. The leak is coming down where is side kick panel towards the cowl area, so I can't see up there untill the box is removed. I will post pics when it is out.
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You must have small hands, no way I could get mine in there!
  10. Slider28
    Slider28 Member
    San Antonio, Texas
    It appears to be leaking around the hole where the flange might have been welded on... It SLOWLY starts to get wet like seeping though...
      File size:
      178.3 KB
  11. Slider28
    Slider28 Member
    San Antonio, Texas
    I had bought some KBS floor pan and trunk sealer for my floor pans.. Since this MIGHT not be to bad, do you think that stuff might work to seal it?
  12. William623
    Orlando
    1973 ford maverick grabber
    If it is just in that area you should be able to use a sealer. Done it on a few cars that have had tiny holes. Just make sure to use a decent amount.
