Heater Control Valves
Discussion in 'Technical' started by Slider28, Feb 25, 2010.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    Well its a new Heater Core. so i know it isnt plugged up. I ran water through it when i got it so i know its free...
    Chaz
  2. 71gold
    so then when a heater core starts clogging up then it gets hotter...:rofl2:
  3. Craig Selvey
    Not if you fan blows too much air across it that it cools off the heater core, preventing it from ever heating up.
    It is a delicate balance. :D
  4. mojo
    As far as I know, most if not all heat control valves of the 70's and prior, were manual. Adjusting the temp control lever control water flow thus amount of heat produced. :hmmm:
  5. Dave B
    Wow, this is very interesting....
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Well,,, May as well add this, certain cars back in the era had trouble heating if hoses were hooked up backwards. Don`t think Maverick was one of them,,,
  7. simple man
    simple man Member
    Bunnell,Florida
    My car is a 74 with factory AC. My valve is vacuum operated. when I took it off I replaced it with a ball valve from Ace Hardware. I plugged both the vacuum hoses,it has two,and have actually just left the valve open. It makes no difference in how the AC works,so I`m not sure of why it`s even on the car. It is a mystery to me! The heat is regulated by a blend door in the heater box. Both heat and air work great with this valve totally open!
  8. bmcdaniel
    The lever controls the air mix door Bryant mentioned. In cars without a coolant control valve the heater core always has coolant flowing through it. All you do is control the airflow through the core.
  9. mojo
    Ok! Im really new to this type of vechicle - So I really can't challenge what Im hearing.
    My question is w\ hot water in the core continously when you have AC running, an open the air door to the pass compartment u get hot-cold mix?
    If the valve has no use why mfg's put them on?
  10. Mavman72
    Back in the day... AC wasnt as efficient as it is today. In order to allow the AC to work at its best cooling the passenger compartment.The flow of hot coolant through the heater core was stopped by the valve so hot air couldnt mix with the refrigerated air.
  11. 69shelby
    69shelby Member
    The valve is there so the a/c is is not working so hard to cool the cars interior. When the temp control on the dash is about 1/2 the valve begins to close and restrict flow. When at full cool the valve is fully closed so the a/c is not tring to cool the heat from the heater core just the incoming air from the cowl intake. This is the reason for the two vacuum lines to the valve as this is for the 3 stages. full open / 1/2 closed / fully closed.
    Hope this helps
  12. simple man
    simple man Member
    Bunnell,Florida
    This is great! I think my mystery has been solved. I`ll just open my valve for winter and close it for summer!
    Thanks everyone!:thumbs2:
    P.S. I`d get an original valve if I could find one at a reasonable price.
  13. 71gold
    i went to my parts Guy and went through his book, picked out the valve i wanted, payed him $14 and went home...:outtahere:
    ...:chirp:...
    [​IMG] [​IMG]
  14. simple man
    simple man Member
    Bunnell,Florida
    Who`s your parts guy? Ford wants $100 for the valve here.:)
  15. 71gold
    Butler Auto Supply Co. (David)...:thumbs2:
