Heater hose from control valve to heater core
Discussion in 'General Maverick/Comet' started by duramax59, May 25, 2016.
  1. duramax59
    duramax59 Member
    Ohio
    Any one know where I may be able to find the molded hose from control valve to heater core ? Thanks for any info
  2. Craig Selvey
    For a factory V-8 with factory AC?
  3. duramax59
    duramax59 Member
    Ohio
    Sorry forgot that info but yes for a 1971 model with a 302 and factory AC.
  4. Craig Selvey
    Yes there is a prebent hose. As far as I know...it is no longer available. I went to the auto parts and looked thru all their hoses to find one that would work.
    Here is the hose I found (and used on my car): NAPA 11049
    It is a heater hose for the 2000 Chevy Malibu/Olds Cutlass with the 3.1L V-6. On my notes it says "Heater to Pipe #1"
    I recall I had to cut it down some, and rotate it on one end by a 1/4 turn.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
  6. duramax59
    duramax59 Member
    Ohio
    Thanks Craig I'll give that a try.
    Thanks jasonwthompson I did see those and I may have to research them a little more. My thinking is if it was close to fitting then it would have a listing- fits Maverick- but what do I know.
    Thanks again everbody
