Heater vents?
Discussion in 'General Maverick/Comet' started by murray, Dec 6, 2021.
  1. murray
    murray Member
    ontario
    74 maverick
    Have a 74 maverick 2 door 250 six with air conditioning ,having an issue with venting that everything blows to floor an nothing to windshield for defrosting? Had a heater core replaced recently ? Any suggestions on how to get all venting to work .
    Thanks
  2. 71Mavrk
    71Mavrk Member
    Nevada
    The doors are actuated by vacuum. The hoses enter the firewall near the heater core. You should see a rubber plug with several lines running inside the car. They go to a distribution block on your heater control. Check for leaks.
    Micah
  3. murray
    murray Member
    ontario
    74 maverick
    Ok thanks I will have a look!!
  4. Craig Selvey
    Normally the default setting , if there is a total loss of vacuum, is to the defrost setting. Strange that you are only getting it to come out the floor vents. Having said that, I would still look at all the vacuum related items. There are several vacuum motors/switches and lots of vacuum lines under the dash.
  5. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    Hopefully there isn't something wrong with the blend door in the heater box.
  6. mojo
    He mentioned had heater core replaced; whoever had box out should have inspected all that while working on the unit.
  7. murray
    murray Member
    ontario
    74 maverick
    Thanks Craig I have to check it all I get full blow to flooring no where else now car came from texas maybe previous owner did some so he had air conditioning blowing full to floor area???
  8. murray
    murray Member
    ontario
    74 maverick
    Thanks everyone for the input here I appreciate everyone help
  9. Craig Selvey
    Does the car have factory AC or is it dealer added AC?
  10. murray
    murray Member
    ontario
    74 maverick
    Factory A.C. !!
  11. TeeEl
    TeeEl Senior Member
    Colorado
    Either a vacuum line is disconnected, or your vacuum storage canister under the hood likely needs replaced...
  12. murray
    murray Member
    ontario
    74 maverick
    I have a good look at it thank you. I'm just wondering when I had it in garage to have a new heater core installed they disconnected something an didn't bother to re hook up?
  13. TeeEl
    TeeEl Senior Member
    Colorado
    Definitely possible...
  14. murray
    murray Member
    ontario
    74 maverick
    Hi Craig off post question do you still sell part I have got some off you in past what I'm looking for is the centre link for the 74 maverick with power steering they are pretty rare to find in Canada if not at all seems lots for manual steering but none for mine with power steering?
  15. Craig Selvey
    Best to email me DIRECTLY (see below) as I seldom get on here anymore.
