Heck of a time getting springs compressed and into position.
Discussion in 'General Maverick/Comet' started by scooper77515, Mar 31, 2013.
  1. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I used one I purchased from Montgomery wards when they closed. assorted spring caps an a long threaded bolt. Wish I could show a picture.
  2. John Holden
    John Holden Member
    NJ
    I use a set like the ones in the second picture. They have two hooks at the top and two hooks at the bottom. I install it with the operating nut at the top so I can just use a 1/2" ratchet through the top of the shock tower to compress it. I had to cut the long center bolt to make it shorter because it would hit the bottom spring perch before the spring was compresssed enough. I've done it a dozen times with that tool and it works perfect every time.
  3. blugene
    blugene Senior member
    Some of you may or may not realize it but Scott has no shock towers. He has a MII style suspension and the coil spring is now on the lower A frame.. I am thinking it is tight/dificult working close to the ground using any shaft style compressors..
  4. rthomas771
    This is why I suggested squeezing the spring in the middle.
  5. mojo
    Where did u get that type of compressor?
  6. rthomas771
    Rented it from AutoZone for $25 about 15 years ago and never returned it. Best investment I ever made. I removed about 20 pairs of springs so far getting greasable spring perches from early Falcons and Comets at the junkyard or replacing or cutting coil springs on my cars. It is the same compressor shown in the first post in this thread.
  7. krelboyne
    krelboyne Remember
    Salem, Oregon
    I have only worked on Mustangs and Cougar, but didn't you compress that spring upside down?
    I mean, I like to have the nut coming out of the top of the shock tower.
  8. rthomas771
    To remove the coil...the fork is too long to fit inside the top of the shock tower is the reason for wrenching it upside down. To remove the spring perch...I put the fork on top of the shock tower and use a ratchet to compress the spring enough to get the spring off the perch.
  9. scooper77515
    I am thinking about buying my own set, for this exact reason.
    Gene is right, I have no shock towers, but the setup is similar, only the larger access hole is in the bottom, and the shock bolt comes out the top, so it is upside down compared to the shocktower setup.
    I can get the double-double hook with single screw from JEGS or Summit for $30-40, maybe even harbor freight or Northern Tool. Then I can trim off some of my screw so it doesn't hit at the end.
    I have a rented set of the ones like rthomas is using, and they work fine at compressing the spring, but with that big duck-bill sticking out both sides, it makes it hard to put the spring into the correct rotated position. You would have to have those forks sticking in just the right place, and even then, I am not sure I can make it clear both sides to fit it into the correct space, one or the other extending part will hit something.
  10. 71gold
    check with Willie at R&C...see what he suggests...
  11. mojo
    I have been lookin at the dbl-dbl hook type and wondering/asking what do the folks use that type might comment on as far as safety is concerned, compared to other type? I have always been hesitant abt removing springs.
    This is probably the right time and thread to inquire!
  12. John Holden
    John Holden Member
    NJ
    Spring compressors always make your a-hole pucker a little. However, I feel relatively safe with the double-double hook style(as they have been "dubbed"). My opinion us they're the lesser of the evils. I wouldn't trust my life or safety with any spring compressor bought from Harbor Freight though. Some things just aren't worth being cheap over.
  13. mojo
    I agree John. I will probably buy one frm Eastwood #49016 the nx time I place an order w/ them. I think the 3 piece unit for $50.00. I have some suspension work to accomplish.
    BTW: I viewed all the pix u have on photoshop :thumbs2:
  14. lastchance
    lastchance Member
    Hingham , Massachusetts
    Try using one hook of two hook puller with a piece of threaded rod through the upper shock mount hole.A couple of washers and the correct size nut will compress the spring. Just have to get the spring in the right position to sit on the lower arm.
  15. John Holden
    John Holden Member
    NJ
    Me, what pics??
