HEI-type distributor cap on stock distributor
Discussion in 'Parts Interchange' started by scooper77515, Nov 3, 2006.
  1. scooper77515
    Thanks to you for doing the bulk of the legwork finding the part number for me (y)
  2. maverick75
    Looks good , i've also seen wires with 90 on both ends.
  3. scooper77515
    I used these wires because they were "donated" by NAFORD to help test out this cap. If I ever buy new ones, they will be 90 on both ends.
  4. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Well How Did It Run Out On The Road
  5. scooper77515
    Never had a chance to run it. Runs GREAT in the garage. Just had family over all weekend and never had a chance to take it out.
  6. scooper77515
    Well, finally took it for a spin. It ran fine at high speeds (and low speed), but I still have that take-off hesitation I had before-hand. I am pretty sure that is carb jetting. It works fine while the weather is cool, then when it hits 80, it starts to hesitate again. This time of year, it is 60 one day, 80 the next, until mid December.
    But the electrical part seems to be running just fine (y)
  7. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    glad to hear its running good , execpt for the hesitation, are they jets to small?
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Hesitation at take off is usually the accellerator pump.
    The jets only work alone at a steady cruise, so that is where they show symptoms of problems.
    Dave
  9. scooper77515
    I think both are an issue. But I believe the accelerator pump is my current issue. I noticed that this started to happen when the weather started to cool, and initially thought I needed to rejet it due to the winter fuel being introduced. I messed with the rods a bit, and got most of it to go away, but it was in the low 60s that day. Next time I drove it (yesterday) it was in the high 80s, and it is "burp"ing again.
  10. bmcdaniel
    Accelerator pump or the idle mixture screws are set too lean.
  11. scooper77515
    I think the idle mixture is fine...more likely the acc pump. Haven't had time to mess with it. Gotta get the manual steering installed, then look up what to do to fix the acc pump...
    Right now, I am not driving it...but is is driveable, in case of emergency, if one of the other vehicles was to fail... :huh:
    Edit...Now that you mention it, I might need to adjust the idle mixture, since I have swapped out the rods and all that...
  12. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    1973 Ford Maverick Grabber ginger & white factory 302 c-4 car LDO package
    okay guys dirty secret time >;0 ford large caps can be used on points distributors.. all you need is the middle cone the cap and the correct rotor you can swap points caps onto duraspark dist.. msd sells a complete conversion.
    for you guys not in the know msd is a smart company and knows how to recycle.. I have proof...
    first i have a msd street billet dist it uses a gm advance system in it.. which is fine with me but it uses a ford pickup.. all msd billet distributors that require a control box use 2 wire ford duraspark pickups >;) all they do is graft the advances onto the pickups us a gm cap and rotor (or a large cap conversion using a ford cap..)
    my 2 cents worth
