Helbragga, Maverick of the Apocalypse
Discussion in 'General Maverick/Comet' started by Helbragga, Aug 22, 2016.
  1. Helbragga
    Helbragga Member
    Durham, NC
    1972 Ford Maverick
    This is how my 72 200ci Maverick project is looking pre-liftshackles. We just put the shackles on in the rain and it looks great. Chopped off the exhaust and installed a cherry bomb. Sounds... amazing.
    Looking to get suggestions for a 200ci dbl bl carb that would work well. Never bought a new carb, always had rebuilt, and this one is an old single. Also, suggestions for header and manifold options for more apocalyptic look?
    I was thinking of cutting a hole in the hood and installing a huge breather. Anyone ever done this? And who sells good huge breathers or cheap turbochargers for a 200... orrrrr should I take a job at AutoZone and get a crate 302 for 1200$ and just start there?
  2. z28th1s
    Lynchburg, VA
    Not sure if you are serious or not? :huh:
  3. Helbragga
    Helbragga Member
    Durham, NC
    1972 Ford Maverick
    100%
  4. William623
    Orlando
    1973 ford maverick grabber
    Just buy an explorer motor 96-97. They work great!
  5. Helbragga
    Helbragga Member
    Durham, NC
    1972 Ford Maverick
    Done that before? Know of a good guide?
  6. William623
    Orlando
    What do you mean? There is one in my friends car and going to be putting one in my car soon. They come with gt40 heads and are full roller motors. You can usually get a low mileage car for around 800 dollars.
  7. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Hope those are not bullit holes! So dark ,so gothic wow! Put a Holly 1904 on that baby ,it wont viberate apart and has plenty of Flow-CFM! The 1904 Holly made mine wake up big time. You will need the International Harvester air filter adapter. You can custome cut out the base of a stock six airfilter to complete. The throttle cable will be tricky!
  8. mav man
    mav man Member
    wi
    70mav
    Just get the 302 in the long run you'll be better off.
  9. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I am not sure if a hole in the hood with huge breather and rain would go together well.
    mav man likes this.
