Hello Everyone!
Discussion in 'New Members Forum' started by Noahg, Dec 3, 2015.
  1. racing ranger
    racing ranger Member
    Iowa
    72 Comet GT Boss Powered, 83 Ranger S/G, 94 F250 Styleside 4x4, 2007 Ford Focus SES
    :cheers:Welcome Noah.
  2. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Welcome to the Forum!
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  4. Noahg
    Noahg Member
    1973 Ford Maverick 4 door
    Thanks everyone! So I'm thinking I may want to do a manual steering conversion as apposed to the power steering. My wheel has a lot of play then steers hard when it catches again. Would converting it possibly fix it or would it actually be the whole steering system?
  5. Craig Selvey
    Sounds like you have issues with your control valve or slave cylinder. It would be up to you to either repair it or convert to manual steering. Your current system is repairable.
    Noahg likes this.
  6. Noahg
    Noahg Member
    What kits do you think I would need to rebuild the power steering components? Would I need a power cylinder rebuild kit?
  7. William623
    Orlando
    1973 ford maverick grabber
    Go on rock auto or your local auto store and just order the power steering ram rebuild kit and control valve kit. They aren't that expensive, the ram is fairly simple. The control valve is a bit trickier, but the biggest thing is keeping it clean during the rebuild!! You will also need a new powersteering boot for the ram.
  8. 71gold
    manual drag link and pitman arm will eliminate all leaks in the pw system. I rebuilt my system only for it to start leaking again shortly there after.
    I drive my car... (avg. 5,500 miles a year) with a lot of...:chirp:
  9. Krazy Comet
    Welcome
    For that leak, easiest way to fix is use a tubing cutter(NOT a hack saw or similar) and cut the line at the leak, probably be best to cut out a 3" or 4" length... At that point you can use a piece of hydraulic hose and clamps to reconnect ends... About any auto parts store will have the parts and tools mentioned...
    Note as mentioned use brake cleaner to thoroughly clean prior to cutting line...
  10. Noahg
    Noahg Member
    Alright thanks for the info everyone. What I ended up doing so far was get new transmission lines, and had to cut them to get it in but they're attached well now with a sleeve. The part where it was leaking was right at the 180 degree bend near the radiator so I couldn't cut and fix that part without a kinked hose or something. I'm now going to convert to manual steering because I'm leaking fluid in I think more that one place and I've heard there are a couple other benefits to manual (as well as down sides). I'm having a hard time finding junk yards near me with old cars though kinda sucks. Once I do the manual steering I was to do a 4bbl carburetor then work on the interior then anything else that needs work after that.
  11. Noahg
    Noahg Member
    Also anyone know what the little pump looking thing closest to the passenger seat in the engine bay is? Don't have a picture yet but it sits right under the hood attached to the fire wall I believe. Mine was rusted and had no hoses connected to it when it looks like it should have
  12. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Can you take pic of it?
  13. William623
    Orlando
    Are you talking about the charcoal canister?
  14. William623
    Orlando
    Little blue thing with a hose connecting to the air filter
  15. Maverick Dude
    Opened the hood on mine. I'm thinking it's your charcoal canister as William623 figured. One line connects to the top of the gas tank and a larger line connects to the air filter housing. In my 73 Mav the function is to collect vapours from the gas tank, store them in the activated charcoal in the canister and when the car is started these vapours get sucked through the air filter and into the carb to get burned in the combustion chambers of the engine. Search " charcoal canister" to see how guys have handled the issue. MD
