Hello everyone!
Discussion in 'New Members Forum' started by killit, Jun 3, 2017.
  1. killit
    killit Member
    Houston
    73 maverick
    IMG_1169.JPG IMG_1178.JPG IMG_1182.JPG So just thought I'd say hello to everyone and see if you guys can't answer a question for me.
    A few weeks ago I picked up a 73 maverick 250 with 80k miles. Planning on dropping a 302 in it in about a year or so (once I can find a good deal and rebuild one).
    Car runs & drives great! I'm really loving it! I built a 69 nova many years ago and already I like the maverick so much more!
    A few days ago I was driving to work and noticed the car was getting hot (could smell the antifreeze before the light even came on). Was only a minute from work so just made and popped the hood. The belts that turn the fan / water pump, ac, and alternator weren't spinning. The ps pump was though. Turned the motor off and spun the fan by hand and it turns easy (none of the other pulleys are seized). It looks like the pulley attached to the crank split in two... so the two grooves that are supposed to spin the fan is just slipping on the rest of the pulley.
    I've tried searching for crankshaft pulley & harmonic balancer online but none of the picture look like what I have. So I don't know if I'm calling it the wrong thing or what but any help would be greatly appreciated. And if anyone has one lying around I'd love to take it off your hands.
    I don't want to invest too much since I plan on swapping the 302 later but I would love to get it moving again.
    Thanks in advance guys!
    Jonathan
    Crazy Larry likes this.
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    :Welcome: to the forum,
    I'm sure someone will have a pulley for you if that ends up being what you need. Post an ad in the "wanted" section for better results.
  3. killit
    killit Member
    Houston
    73 maverick
    What would I call it? Crankshaft pulley?
  4. Maverocket
    Northwest
    Yup!
  5. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  6. mav1970
  7. z28th1s
    Lynchburg, VA
    :Welcome: from central VA!
  8. killit
    killit Member
    Houston
    73 maverick
    Sweet! Thanks brotha!
  9. 71gold
    :Welcome:...:Handshake:...clean looking car...:thumbs2:
    " the two grooves that are supposed to spin the fan is just slipping on the rest of the pulley."
    the problem you describe sounds like a unique one...I've never heard of a pulley splitting...:huh:
    may we see a pic of this?
  10. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Welcome to the Forum fellow Texan !!!
  11. Krazy Comet
    Well that's wierd but sounds like the crank pulley has separated... I know some have outer sections welded to the inner...
    I'd pull it off and take a look(maybe get it rewelded?), the harmonic balancer just about has to be OK or the P/S would not be spinning...
  12. killit
    killit Member
    Houston
    73 maverick
    Yup I'll try to get one tomorrow... it's been raining like crazy here!
  13. killit
    killit Member
    Houston
    73 maverick
    That's what I was thinking!
  14. killit
    killit Member
    Houston
    73 maverick
    Quick little video of the issue
  15. Maverocket
    Northwest
    That's definitely separated. Should be able to have it welded.
