Hello from Germany
Discussion in 'New Members Forum' started by Cateye, Jul 8, 2017.
  1. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada!
  2. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    Hi all, first work is done. car is stripped and the ordered spare parts are delivered. So the sheet metal work is done , it was a lot of welding work to do – o.k. it´s an 44 Years old car but sometimes I wonder on which places I found the holes ;-).
    After this work was done I work to change the Drum brakes to power disc brakes. My 1st step was the change of the brake pedal incl. the bracket, 2nd step was an new power brake main cylinder, 3rd step is now under work – I ordered a wildwood brake kit (only front brakes ) for the Maverick, looks easy to install – let´s see if it works really so simple ;-)
  3. mojo
    Welcome to the forum...Do you have some pictures?
    71gold likes this.
  4. nidus
    nidus Member
    California
    71 mercury comet gt, 75 CB550, 76 CB550
    Welcome :wave:
  5. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    Some Pics before, was not so bad for this age :
  6. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    here are some further pics
  7. yellow75
    Tillamook Oregon
    Well its not the worst rust we have seen but the rust in the cowl and A pillar will be fun to deal with. Too bad you are in Germany getting replacement metal will be harder to get hopefully tody can help out but you will probably be forced to make your own patches
  8. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    Yep, would be easier with replacement sheets, but we create our own patches, the pic from the b-pillar shows a part of the welded buttom driver back side. I use zinc plated sheets with a thickness from 0,06 inch
  9. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    here are some more pics , shows the metal work on the car:
    A-Saeule.jpg Blech 1.jpg Blech 2.jpg BODEN 1.jpg Brake 1.jpg Brake 2.jpg B-Saeule 2.jpg B-Saeule.jpg Hole 2.jpg Hole.jpg Window 1.jpg
  10. racing ranger
    racing ranger Member
    Iowa
    72 Comet GT Boss Powered, 83 Ranger S/G, 94 F250 Styleside 4x4, 2007 Ford Focus SES
    :Welcome: From Iowa USA
  11. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    I work now on the front suspension and the front brakes. Lower and upper control arm is changed, also an upgrade from drum – to wilwood disc brakes. Shock absorbers are also changed
    tody and Hotrock like this.
  12. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    So time is running fast when you work on an old car, most of the technical issues are fixed and the paint job is done. I work now on the upholstery and the details to bring the Maveric back to the road. Back.jpg Front.jpg Door.jpg Speaker board.jpg
    mojo, 71gold and Hotrock like this.
  13. Hotrock
    Munroe Falls, Ohio
    Don't forget to update your Garage posting.
    I like your door panels!!! :thumbs2:
  14. Cateye
    Cateye Member
    Germany
    Maverick Coupe 1972
    Thanks, the panels are "home made" it´s vinyl and wood. Armrest is an refurbished one from an old Mustang. Next challenge is to install the headliner - no experience with this kind of work.
  15. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Wow! This looks amazing!
