Hello!
Discussion in 'New Members Forum' started by Bursa, Dec 14, 2020.
  1. Bursa
    Bursa New Member
    Turkey
    70 maverick
    A6B4A67C-14D1-4D78-81A9-E587F93A99F1.jpeg 419F108E-5B2E-4D08-9AB6-0DE685ED6B0B.jpeg Hi guys. My name Mustafa. I’m from Turkey. I’ve 70 ford maverick. I've been restoring my car for a long time. I have a question for you. I have a 5.0 efi engine. but I have a stock differential in my car. (6 cylinder differential) do you think it will be a problem?
  2. mojo
    Welcome to the forum form northeast Illinois!:Welcome:
    I would say, depends on how you drive it. If your going to drive it really hard; my guess, you will have issues down the road...
  3. Krazy Comet
    Dismal Swamp
    WoW, that's going to be nice!! Welcome to board!!
    If you're saying 6 cyl diff with with rear cover, it'll not stand much abuse. Will probably live with full throttle once car is rolling, but burn outs, hard gear changes, etc are off limits..
  4. 71gold
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    That is a beautiful car! Welcome from Portland, Or. If that rear is 5 lug, isnt it an 8" ?
  6. PirateSteve
    PirateSteve Member
    Las Animas county Co.
    1972 Maverick 2dr, 302 automatic. 1974 Comet 4dr, 250 automatic.
    Hello from Colorado.
    Yes, I noticed the 5 lug fronts as well.
    If that's an 8" (3rd member housing/aka no inspection cover) you should already be set. Unless you plan to throw some real power down. Then I would upgrade to a 9" or at least an 8.8". And might as well go posi.
  7. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    Hello from Nevada. If you have 4 lug axels with adaptors the 9" drum brakes aren't going to stop you very fast. As for the center section. If it is a drop out 8 inch as long as you are not going to run slicks you should be fine. If the axels are four lugs, that is what fox bodies came with and unless they were severely abused the didn't sheer off too often.
  8. mav1970
    :Welcome: from Northeastern Pennsylvania USA
