Hello
Discussion in 'New Members Forum' started by cdeal28078, Feb 18, 2005.
  1. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    What are you running right now Zaperboy79? Does yours have a 302 in it already? If so alot of horsepower is left on the table buy not having it tuned properly. Alot of power can be found by setting up your initial and mechanical timing properly. A stock 302 would probably run good with around 10 degress BTDC intial and then set up your mechanical advance to be all in by around 2800-3500 and go up to around 34-38 degrees.
    Don't worry about your vacuum advance, if you have it, until you get the mechanical fixed. Then if you have adjustable vacuum advance you can tune it while driving it around and adjusting it until it spark knocks on a lugging hill then backing off until it stops
    clint
  2. das351965
    das351965 Member
    sc
    2-71 mav 1-71 grabber and 75 4dr parts car
    hey welcome and the mav looks like it is in pretty good shape good luck with it.the guy &gal around here are good they don't mind helping with any question and they know there stuff.
  3. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    :Welcome: Clint
    NIce project you got there. THe 302 is a great motor and should work great for you. NIce thing is if you want to go fatser you can always add a few things like a better intake and carb later. GITER DONE!!!:clap:
  4. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Thanks 1badmav, I'm thinking 289-302 is the way to go. I have a 351w I could use and I know that would getherdone but may be overkill for my daughter. If I get to build me one I'll use the Windsor in it.
    Going to drag the trailer down the road this morning and look at another one a friend called me about. It's a 72 and sounds like it's in good shape with rolled leather interior. 200ci auto. Manwants $350 firm for it. If it looks half as good as he says it is it'll go on the trailer.
    clint
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Welcome, looking forward to pics of the progress.
