help 245 60 15 tires rubbing
Discussion in 'General Maverick/Comet' started by bLaH_hA, May 25, 2010.
  1. Craig Selvey
    I will sum it up for everybody:
    Those wheels are WAY to wide
    Those air shocks WILL eventually plunge thru your trunk floor.
  2. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    I can testify to that. when i bought my car, the shock was still hanging in the floor board between trunk and back seat.:yup:
  3. 71gold
    i bet on the 10" rims they will rub also...:yup:
    buy 2 of the right rims and tires and get the other 2 later...:tiphat:
    ...:chirp:...
  4. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    0526101122-01_original.jpg you cant tell but i have the bracket reinforced with some welds.
    as for backspacing what should i get for the backs? 15x8 wheel but offset and backspacing?
  5. justin has a 74
    kentucky
    So its the stock bracket with welds?:hmmm: that isnt going to solve it (or so im told:D)
  6. bmcdaniel
    All cars are little different, things get tweaked, people change rear ends, etc. For example, I have 15x8s but with 6" backspace. You know what you have now, using that as a guide, measure to see what will fit.
  7. Craig Selvey
    Welding the brackets will be of no benefit. It is the thin steel that the brackets are fastened (now welded) to.
