Help 3 of my doors wont open
Discussion in 'Technical' started by Blackstarcj, Feb 16, 2013.
  1. 71gold
    my thinking is..it wasn't...:smash:...out of adjustment so why...:smash:...it back in...:cry:
  2. zackarthurb
    zackarthurb Member
    Eastern NC
    1973 Ford Maverick
    I had to take my panel off and lube up all the internals.
    Not hard to do, took about an hour or so., You can use a screwdriver to pry off clips behind the panel and if you are careful it wont tear the back lining. Watch out for black gunk.
  3. Blackstarcj
    Blackstarcj Member
    Philadelphia
    1972 Ford Maverick
    ok i got 2 of the 3 doors open now one still wont open my teacher said its the latch on the door
  4. hyperballsmcgee
    hyperballsmcgee Member
    Murfreesboro, TN
    1974 Maverick 2 door
    But it was. My car was hit on the driver door by a moped or something.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The best solution to the problem is to sell the car and get yourself a 2-door model.
  6. Blackstarcj
    Blackstarcj Member
    Philadelphia
    1972 Ford Maverick
    Well I got the 3 door open yesterday Wd-40 + some kicks from my black belt friend and it just opened
  7. 74merc
    74merc computer nerd
    1974 Comet
    I've had to pull door panels on my old 4 door and work the lock. From the outside it wouldn't unlock, from inside (the door, not the car) it would. No amount of lube helped on this one.
    Something on my doors was out of adjustment. My dad helped back then (I was a teenager at the time) and I'm not sure what he adjusted. I think some linkage was bent or worn from use and age.
    I may be able to look at my 2 door and figure it out, but thankfully I haven't had that problem on this car.
