HELP! driveshaft problem
Discussion in 'Technical' started by Zooomzoomguy, Sep 18, 2006.
  1. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    here's a picture of my problem, the car is level on the ground, i tried rocking it, tried loosing trans mount bolts to see if it would move no luck, is that enough? on the frame mounts, they had a tab in the middle of the mount, does that go on the top side of the frame mount or the bottom?
  2. RegL404
    RegL404 Member
    I just looked at my 4dr. and my 2dr. and they both have about 1 and a half inches of the yoke showing(it would go in about 1 and a half inches before bottoming).
  3. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    when did these cars start using harmonic balancers on the shafts? mine does not have one
  4. Jamie Miles
    Alto, GA
    I've had a few
    I think in '74. My '74 Grabber had one, neither of my 73's do.
    This is how far the driveshaft on my Grabber used to stick out. I thought it was to long also, but I put over 6,000 miles on the car with it like that..
    I'm haveing the opposite problem with my 69 1/2. I have the drive shaft from a '73 250/C4 car in it and it seems to be about an inch and a half to long. I'm hopeing the 8 inch rear swap and getting rid of the shackles will correct it.
  5. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    With the driveshaft in the transmission like that. Make a line on it where it sticks out.
    Pull it back out and measure how far it goes in.
    It seems to be real close as to whether it will work or not tho but I think you may be fine.
  6. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    could someone look into the frame mount thing? i know mine had a tab sticking out in the middle, i put that on the bottom thinking thats what the motor mount would rest on when its not bolted in.
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    Mine has a little tab/ledge on the "side" of it that the motor mount would kinda rest on
    Is that what your talking about?
  8. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    yeah thats it
  9. Andysutt
    Conway Arkansas
    1972 Comet GT
    Let me go take a picture of mine really fast
    Maybe it'll help
  10. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    yeah, you can't get the mount in if it were on the upper side of the mount, goes towards the bottom to help locate the mounts, which are the dumbest motor mounts I think I have ever seen
  11. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    but i remember they are off set i think, which way are they supposed to be off set?
  12. Andysutt
    Conway Arkansas
    1972 Comet GT
    Im uploading pics from camera to the PC right now
    I could only get a underneat shot of the passenger side.
    Considering my headers and such are in the way
    My right side as a upside down R on it facing the front.
    Maybe the pictures will help you but I doubt it considering theres no room
  13. Andysutt
    Conway Arkansas
    1972 Comet GT
    Maybe this will help?
  14. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    frame mounts
    just went and looked at my frame mounts, they are off set to the rear of the car so thats right, i have 2 inches of room between motor and firewall so i believe thats correct my trans mount sits center in its double hump mount so thats right also, i think i'm going to try to run it like that and see waht happens
  15. Andysutt
    Conway Arkansas
    1972 Comet GT
    I'd still suggest marking the yolk and pulling it out and measuring how much sticks into the tailshaft first... just to make sure
    Did those pics help at all?
