Help identify this wiring? 74 mav factory 302 car ac removed
Discussion in 'New Members Forum' started by Guitargeek68, May 31, 2021.
  1. Guitargeek68
    Guitargeek68 Member
    Sumner Wa
    1974 maverick
  2. Russell
    Russell Orejano
    New Mexico, 88022
    Maverick
  3. Guitargeek68
    Guitargeek68 Member
    Sumner Wa
    1974 maverick
    Thanks! LOL.
    Im figuring most of it out, but I’m still lost on this one. It comes from the same wiring harness that has the oil and water temp senders. Idk if it goes to the choke, or to the flux capacitor. LOL
    Russell likes this.
  4. Krazy Comet
    Often connectors are meaningless.. I've been working on cars since mid 1960s, I dunno what it is.
    Using a wiring diagram, circuit is determined by color of wire.
  5. Guitargeek68
    Guitargeek68 Member
    Sumner Wa
    1974 maverick
    I’ve been looking at a few. I’m going to have to trace the wire back a little, I can’t tell if it’s solid red, or a purple, or brown because the exposed area is dirty.
  6. 71gold
  7. rthomas771
    I remember seeing something like that going to air cleaner or the vacuum switch bolted to the valve cover...I think. Its been a lot of years since I saw it
    Krazy Comet likes this.
  8. Krazy Comet
    LOL, yeah the mid '70s were loaded with all sort of contraptions. I usually tossed the mess in trash can & connected like the 1967 models. Those ran fine without the snake pit of wires, vac hoses & connectors.
    Brown was color used for outside lights, park, side marker, license etc.
  9. Guitargeek68
    Guitargeek68 Member
    Sumner Wa
    1974 maverick
  10. Guitargeek68
    Guitargeek68 Member
    Sumner Wa
    1974 maverick
    Oops. Did something weird there.
    I’m honestly thinking I might just hook up whatever I can figure out, fire it off, and then see if I even need the rest. Might be some a/c wire that I’d never ever need
  11. fastfords
    fastfords Member
    East Tennessee
    70 Maverick, 71 Comet GT, 72 Sprint, 75 Comet, Maverick Stallion
    I have a connection just like that on my 74 Comet that goes to my electric choke, there is a wire that goes from the choke to that connection.
  12. Guitargeek68
    Guitargeek68 Member
    Sumner Wa
    1974 maverick
    That makes a ton of sense, and I have an inkling that may be the case. I was going to get the battery hooked up and test it for power with the ignition on this weekend. The placement, and length of the wire seems to point towards that very thing.
  13. Krazy Comet
    Supposedly the choke wire is black/white.
    In any case, choke feed connects to alt stator, no voltage unless alt is charging. Choke release only operates with engine running. Some vehicles routed choke power through a multi contact oil pressure sender, again no voltage unless engine running.
    Of course engine could be making a Blam, Blam, Blam! Noise.
    Hey Joe, can't figure out why the choke isn't releasing...:slap:
  14. Guitargeek68
    Guitargeek68 Member
    Sumner Wa
    1974 maverick
