Help me build a reliable throttle setup (anyone using a linkage?)
Discussion in 'Technical' started by MrP, Apr 12, 2013.
  1. MrP
    MrP Member
    1970 Maverick 302
    I see why mine is all screwed up now....I have power brakes (bought the car with front power disc)
    So they just had the cable punching through the firewall and I did the same thing which is clearly not right...hmmm...
  2. rthomas771
    So you're saying if you use a part that the Detroit engineers designed for this particular application in the said vehicle in question then it will work without having any issues? :huh:
  3. MrP
    MrP Member
    1970 Maverick 302
    I don't think I can put it back to stock due to the power brakes.....
  4. Dave B
    Cars with power brakes had them, we just need to find you a good picture.
  5. rthomas771
  6. MrP
    MrP Member
    1970 Maverick 302
    Well. I am missing that. Any ideas aside from the factory stuff?
  7. Craig Selvey
    You have a 1970. Originally your throttle cable came out of the square hole above the valve cover in this picture.
    1970 never had a V-8 from the factory, so you will never find a 1970 Maverick V-8 cable. I think you need to come out of this square hole to solve your issues.
  8. MrP
    MrP Member
    1970 Maverick 302
    Okay, I am going to punch the cable through there, somehow I need the downward angle bracket that some factory cables have. This would probably help a ton.
  9. Craig Selvey
    Plus....it looks like your fancy gas pedal is mounted way too low.
  10. car-nut
    car-nut Glenn
    conn.
    I agree, why is the pedal mounted so low? For what it is worth, I bought a Mustang direct mount pedal set up from Lokar. It bolts right into the exact location as the Maverick. Fits perfect.
  11. MrP
    MrP Member
    1970 Maverick 302
    Okay that pedal may be what I will look into.
    It is mounted to fit where the cable that came with the car was routed into. Which is now found to be clearly wrong. So I will adjust the pedal, and cable see if I can get it working better! Started to replace my leaf springs, but my shackles and bushings are fubard so need new ones of those...never ends.
  12. 71gold
    the intake mounting bracket looks like it is also assembled incorrectly...
  13. MrP
    MrP Member
    1970 Maverick 302
    Do you have a higher resolution photo? I couldn't quite zoom in enough...Could be. Car had a 302 in it when I bought it, I changed everything so far except the carb, wheels, and steering wheel. Oh and the brakes, left the power front disc alone.
  14. rthomas771
    Here's the drawing.
