help me with front back spacing please
Discussion in 'Wheels and Tires' started by satchelmcqueen, Aug 31, 2017.
  1. satchelmcqueen
    satchelmcqueen Member
    rome georgia
    so im going with stock height and suspension. i have the stiffer leafs on back but otherwise the suspension is stock rebuild up front in factory form using v8 springs.
    so the wheels on the back im going magnum 500s 15x8 with 4.25bs using a 275/60/15 tire.
    on the front i am going to magnum 500s 15x7 with NOT SURE bs. ill probably be using a 235/60/15 tire. what bs should i get for the front wheel? ive been told 3 1/2 to 4". whats your take?
  2. mojo
    I wondering/doubt U will be able to run the 2.75's w/o rubbing leaf springs?
  3. 71gold
    on the rear I ran 275/60/15 tires on 15 X 8 X 4.50" BS.
    Futura GLS Super Sport
    front were 15 X 7 X 4.00 BS.
    satchelmcqueen likes this.
  4. satchelmcqueen
    rome georgia
    Ok so I'll go 4bs on fronts. Ty
  5. satchelmcqueen
    rome georgia
    I'm going to give it a try. If not I'll see if I can swap them next size down.
  6. 71gold
    next size down in a 60 is...255 X 60 X 15
  7. satchelmcqueen
    rome georgia
    looks like mag 500 for the size i want is the following....
    front is 15x7 - 4 1/4bs.....will this work and NOT rub?
  8. satchelmcqueen
    rome georgia
    EDIT: i found the answer from larry in another thread. so thanks guys. ill be getting 4.5 bs on rear and 4.25 on front. thats the best i can do with these magnums it seems. i was hoping to go a 1/4 less with each to be safe, but ill have to make it work somehow if i have issues.
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    Hello
    Maybe this can give you an idea, earlier in the year I bought a set of magnum 500s. The fronts were 215/60 on 15x7 and rears were 265/60 on 15x8 with 4.5 backspacing and 0 offset, the wheels themselves look good but I didn't really like how far they stuck in under the car, I eventually went with a set of new slotted mags with 4 inches of backspacing on the rear and am a lot happier with the wheels now
  10. Crazy Larry
    Crazy Larry Member
    Sanbornton, NH (originally from Colorado)
    For a 235 up front, you're gonna need a 4" backspace.
  11. 71gold
    what brand...265/60 on 15x8...?
  12. x72COMETx
    x72COMETx Member
    Vallejo CA
  13. satchelmcqueen
    rome georgia
    wheels and tires ordered. got some mickey thompson sportsman st. 275/60/15 and 235/60/15.
    my measurements say they will fit. lets see when they get here.
  14. 71gold
    on the 275s, if the section width is the same as the...Futura GLS Super Sport (10" SW)...they will work...:thumbs2:
    on my Futura GLS Super Sport (10" SW) I had spring and wheel lip clearance...:yup:
    mickey thompson sportsman st. 275/60/15 (10.70")
