Help the carburetor moron!
Discussion in 'Technical' started by CACollo, Jun 18, 2002.
  1. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    P.S.--i like that post about the no carburetor too big...it's a good point. I guy i used to work with had a friend with a "fairly" modified 302, and he ran a dominator on it. The funny thign was that it idled like crap (if you could call it idling), but man when that thing revved up....
  2. marcua56
    marcua56 Member
    omaha
    maverick
    Dose anyone in here know how to a just the carb for the 250 ci 76 maverick. it seems to be running a little rich and im new to this stuff.
  3. don graham
    i run a 750 hp holley double pumper on my 308. works great. those d0 heads are 1970 and are probably just as good or better than the d7's. even if they came off of a 94 stang they are not original for it. if i was going to change i'd save up and go for a set of aluminum heads.:)
  4. rayzorsharp
    Hey Don...this post is 4 years old. I bet he's got it all figured out by now. :rolleyes:
  5. don graham
    ha-ha, i didn't even notice the date. my internet just came back on a couple of hours ago, been off since last night, and i've been trying to get caught up.:rofl:
  6. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Yep, but that doesn't address the rate it takes to get to 6000 rpm, which is the whole point with performance parts.
    Mavman is spot on.
  7. koonswala
    koonswala Member
    Winnsboro, LA
    maverick
    check the timing to see how it is sitting that was our problem
  8. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    No both of you are spot on. (y)
    If they didn't make more power than nobody would run them,:29:
