help with directionals
Discussion in 'New Members Forum' started by mbow, Jun 15, 2013.
  1. mbow
    mbow New Member
    Massachusetts
    1971 maverick
    hi,
    New member here. Have a 1971 Maverick and the L & R directional don't work. All lights work, and hazards work. Have replaced the entire switch assembly on steering wheel. Have replaced flasher....wiring diagram shows 2 flashers..one for turn signal & one for hazard...but I can only find 1 which is next to fuse block..when I remove it, the hazards stop...is there a 2nd one I cant find for turn signals? any other ideas?
  2. mav1970
  3. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  4. Mavaholic
    Yes, there is a second one up under the dash, I dont exactly remember where, but I believe its up between the heater controls and instrument panel.
  5. 71gold
    :Welcome:...:Handshake
  6. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    :Welcome: from Lizella Ga.
    My 75 model does have one between the steering column and the heater controls. It is difficult to see and reach.
    Ray
  7. Bumble1970
    Bumble1970 Member
    Rhode island
    70 Ford Maverick grabber 6 cyl
    Drivers side directionals flash/blink as normal but passenger side doesn’t (Hazards work fine) so I’m assuming I need to replace the directional flasher which is hard to get to from what I’m reading. Any suggestions on how to replace it without removing the gauge cluster? Thanks!
  8. Krazy Comet
    Yeah, don't remove cluster, ain't necessary.
    Remove Steering wheel, screws that attach signal sw & unplug connector from under dash. Will pull out.
    DGD likes this.
  9. Bumble1970
    Bumble1970 Member
    Rhode island
    Thanks, I’ll give it a try.
  10. DGD
    DGD Member
    IND
    Howdy Shorthorns ! Good to hear about your car.
  11. Bumble1970
    Bumble1970 Member
    Rhode island
    Wasn’t able to get to it the way that was suggested. I did unscrew the dash cluster ( only 3 screws) and just pulled it out enough to see the flasher to the left of the fuel gauge cluster. Not sure how the old flasher is held it but I was able to unplug it, plug in the new one and feed it down to where the emergency brake lever is and just tuck it in there so the next time I have to replace it, I don’t have to take anything apart. Hope this is helpful to others. Thanks!
  12. Krazy Comet
    Sorry was thinking you said signal switch. A flasher 99% isn't going to cause one side to blink but not other. Socket, wiring, switch, incorrect bulb yes.
  13. Bumble1970
    Bumble1970 Member
    Rhode island
    No worries. It worked out well. Thanks
