help with front drum brake problem
Discussion in 'Technical' started by maverick7072, Jan 30, 2016.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I actually know someone, but it's not on a Maverick.
    He has a '67 VW bug, and had a '64 before that. The '67 had a 4-wheel disc conversion that the previous owner did.
    The guy I know is a VW aficionado (I know nothing about them) and says that the disc brake conversions for those cars suck, regardless of brand. He switched it back to a rebuilt 4-wheel drum setup with all new components. He says the cars are so light weight anyway that discs are not needed (and it's not a race car).
    I do know that a 4-wheel disc setup requires more pedal effort if there's no power assist (like on a '67 bug).
  2. rthomas771
    Its because brake shoes have more sq. inch surface contact than brake pads to help slow things down
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I replaced the rubber lines and bleed everything out adjusted the brakes and drove it,it still has a pull to th eleft but not as bad as it was before but the brakes shimy now ,could it be one of the rotors?the hardware still looks good they must of been change out sometime befor ei got the car.
    just so everyone knows I havnt driven this car long distances since ive own it ,no more than a couple of miles and back home,so these problems have been here since ive owned the car and it sat up for a while before I purchased it ,now back to the brakes the hardware looks sorta new still has the color,the pads not that old either ,the driver wheel cylinder was stuck when I 1st got the car so I replaced both sides,now thw rubber lines,The rubber lines help with a lot of the pull but like I said shimys when braking to stop and has just a slight pull to the lleft still,
    Correction not rotors but drums!!
  4. 71gold
    these are disc brake parts...:huh:
  5. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    ok sorry I thought I corrected myself its drum brakes and brake shoes
  6. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    brake Drums and brake shoes I just cant type tonight
  7. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Could a bad strut rod bushing cause this?
  8. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    make sure one of the drums aren't glazed for any reason. they should have like a crosshatch to it. not slick.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    One or more of the drums is warped. They need to be machined true (or replaced if there's not enough metal left).
  10. Krazy Comet
    Dismal Swamp
    Swap drums from one side to other(scuff up the shoes with some 150 or so grit paper)...If pull is still on right it's not a drum problem...
    It could... If wheel is shifting rearward when braking, positive caster increases which will increase pull...
  11. Craig Selvey
    Even new drums need to be turned. I had the same problem on a 1968 Torino I had. New drums.....terrible pulling, vibrating etc. Had them turned....problem cured.
    Crazy Larry and 71gold like this.
  12. 71gold
    I have all my new drums/rotors turned before install...:yup:
  13. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    Krazy comet that's a great idea I don't =know why I didn't think of that thanks everyone else for ur input as well
  14. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    What if the right rear bushing is bad on the right side and is compressing completely forward?
  15. Krazy Comet
    Dismal Swamp
    Traveling forward the rearward thrust of wheel and suspension would be pulling strut rod against front bushing... Should mostly be a problem when backing up, but I could vision issues when turning and clunking/chatter just driving down the road...
    The strut rods are what keeps the lower control arms rigid and in place, otherwise they flop around kinda like a limp -- uuhhh, well you probably can envision my example.... Driving without a bushing is no doubt dangerous...
    Well if it works for you, but chances I'm going to cut a new rotor/drum and reduce thickness are zero & none... If they chatter or vibrate I'll take them back...
