Help with rewiring the car...
Discussion in 'Technical' started by mashori, Aug 18, 2012.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    can't wait to get my car back to this point....
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    this is what it looks like right now
  3. kboldin
    Santee, CA.
    That there is some Spaghettification! Looks like a nice project, I'm sure it will be super when it's all done!!
  4. injectedmav
    injectedmav Member
    Georgia
    how much did that Deutsch connector pack set you back? That's the most complete set of those I have seen yet...:)
  5. 71gold
    X-2...and where did you get them?
  6. injectedmav
    injectedmav Member
    Georgia
    I use that interval wiper arrangement too. 1989 Bronco:thumbs2:
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Got it for 370, found it on Ebay. Found a cheaper set but didnt look as good.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    got to the shop and started working on the maverick, goal was to get all the wiring out of the car and make sure all the splices are cleaned up and that all the connections are as solid and clean as possible.
    this is what I started with ....didn't get as far as I wanted but still a lot done...
    most of the wires is all the stock wiring still in place that I took apart, a lot of splices there...most of what I have done myself over the years, some from the PO.
    pulled all the wiring out!! finally...glad I got that done because now I can really clean everything up...got a label maker to make sure I get everything back in place...
    pretty slim pickings for wires, had to do a wire run but the electrical store near our shop is going out of business, they have almost nothing so I came back empty handed. The wires at NAPA were not what I was looking for.
    look how awesome it looks with all the wires out of there!
    Jay from the board came by to help with the aerodymanics...
    this is the engine side of the firewall, installed a bolt to serve as the ground....everything will ground to this....well almost everything
    bryant started bbq-ing! oh man, so good
    cleaned up more wiring...not using the neutral safety switch from the automatic tranny so was able to remove the wiring....gonna hook that up to the T5 neural switch and reverse switch...
    here is all the labels I made for now so I can get the wires back together starting Monday...
    I have an accessory keyed fused panel that I will install somewhere near the center of the firewall..
  9. injectedmav
    injectedmav Member
    Georgia
    Nice work!
    If you run low on wire again you may want to check your local auto stereo supply house. I have several different colors of 18ga fine stranded wire that is very flexible and great for signal and low amperage requirements.
    The grub looks great too, now I'm hungry!
  10. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Ha Ha Ha
    You guys have chicken on the bar bee and BEER I need direction will be there ASAP . Will bring wire cutters............
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I have a small switch on my clutch pedal that I'm using as a neutral safety start. I used to have it hooked up to a relay and that hooked up to the S terminal of the starter solenoid. My question is do I need a solenoid because the factory setup didn't have one. And if I do, how would I wire the solenoid into that circuit?
  12. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Mo
    I would think you can use the start wire off the ing. switch and run it through your clutch switch ...
    If i'am wrong someone will make it right...
    Jay
  13. Bryant
    the factory does use a solenoid. we used the relay triggered by the ignition switch and clutch switch to trigger the solenoid. if you want to get rid of the relay then you need to figure out the amperage draw of the solenoid and the amperage capacity of the micro switch on the clutch pedal. if the micro switch can handle the amperage load of the solenoid then you dont need the relay.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Bry, you always have the scientific answer! Muchas gracias
  15. Bryant
    im well trained
