help
Discussion in 'General Maverick/Comet' started by Tylermav94, Jul 15, 2014.
  1. Tylermav94
    Tylermav94 Member
    Drumhellar Alberta
    1972 Ford Maverick
    So turns out this part is broken. Idk what it's called or what sites to order from so much help would be appreciated. The motor mounts bolt onto these.
  2. chandler
    chandler Member
    Warrenton Mo
    Maverick
    Post in the wanted part of the forum that you are looking for 302 frame stands. They will run you between $60-100.00.
    If you have access to a torch you can fix that and be going pretty quickly.
  3. Craig Selvey
    I have just one side...so I may have the one side you need. Email me DIRECTLY (See below) if I can help. Send me the pictures as well.
  4. 71gold
    the pieces that is broken off, is it needed...:huh:
    the rest...:smash:
