Help!
Discussion in 'Technical' started by valleyracer, Sep 25, 2007.
  1. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    how big a cam and what size stall convertor:)
  2. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    CompCam Part#31-254-4 and 4800 stall 8" converter lightweight KB pistons on Hbeams
    9 to 1 compression windsor jr cast heads 7000rpm shifts...made 345 horse at the back wheels
  3. daydreamer
    Oshawa, Ontario
    1972 Ford Maverick
    Thks for the info.Nice times, good parts too.I'm using almost the same cam but its mech,not hydrolic. Have a 4800 con,.10 1/2 comp final,all forged internals. I was shooting for the results that you have gotten. thats why my curiosity :Handshake
  4. baddad457
    You really haven't said why they're not working. I've got Hedmans on my Canfield heads and the Ford Racing 9mm wires work fine on reglar old Autolite plugs.
  5. valleyracer
    valleyracer Member
    Ottawa Canada
    the angle the plug comes out is to close to the pipe! The accell shortys and sparkarms from Wrenchrat solved that problem...just brought this post back up to help others with the same problem(y)
