Hey Guys
Discussion in 'New Members Forum' started by Brady230, Aug 26, 2017.
  1. Brady230
    Brady230 Member
    California
    1974 Ford Maverick
    Hey guys! I recently bought a 74 Maverick coupe, just a rolling shell. I'm going to swap a 351W with a C4 tranny. Anyone know or anyone selling the correct motor and trans mounts? Please and thanks
  2. Mavman72
    regular V8 (302) Maverick frame stands and rubber mounts will work just fine.
    And welcome to the madness
  3. Brady230
    Brady230 Member
    California
    1974 Ford Maverick
    I'll look into those. Haha thanks
  4. Hotrock
    Munroe Falls, Ohio
    Welcome to the site from northeast Ohio!!!! :tiphat:
    As Mavman72 writes, V8 pieces will work with the 351W. You are aware the 351W is a tighter fit than a 302 based engine and requires special headers, 351W pulley brackets and a correct flex plate?
  5. 71gold
    :Welcome:...:Handshake:
    all the above plus at least shaving the shock towers.
  6. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Welcome from British Columbia, Canada. There is an ongoing issue of stroking a 302 vs installing a 351. Type in 351W swap in the search section of get lots of info on the pros and cons. :yup:
    MD
  7. Brady230
    Brady230 Member
    California
    1974 Ford Maverick
    Hey thanks ! Yeah it's gonna be a mission but if I can get it to work then it'll work! I'll be on this site with lots of questions very often ! Haha
  8. Brady230
    Brady230 Member
    California
    1974 Ford Maverick
    Hi! Yeah I was gonna shave the
  9. Brady230
    Brady230 Member
    California
    1974 Ford Maverick
    The shock towers. Or send it to a shop
  10. Brady230
    Brady230 Member
    California
    1974 Ford Maverick
    Hi thank you! I certainly will be doing my re search.
  11. z28th1s
    Lynchburg, VA
    :Welcome: from central VA!
  12. Brady230
    Brady230 Member
    California
    1974 Ford Maverick
    Saying thank you from Riverside California!
  13. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada! Good Luck with the 351 install!!
  14. mn67
    mn67 Member
    Great white north
    Welcome. Good luck with the install. The shock tower notching is not bad at all. I have a set of V8 frame stands since they will not work with my FE that I would donate to your cause they are yours for postage. Send a note if your interested.
    nidus likes this.
  15. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    It's members like you that make this forum great! :urock:
