Hey...WAKE UP IN HERE
Discussion in 'Drag Racing' started by riporter, Nov 19, 2004.
  1. Earl Branham
    Lugoff, SC
    Thanks, Rick!
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Ok...here goes:
    347 Stroker.
    Eagle 4340 Crank/connecting rods
    SRP Pistons (13.5 to 1)
    Lunati roller cam....
    .642 intake/.626 exhaust
    255* intake/258* exhaust
    Manley pushrods
    AFR 205 heads (60cc race)
    roller springs (1.550)
    steel 10* valve locks
    7/16 rocker studs
    2.131 (intake)
    1.65 (exhaust)
    Lunati roller rockers (1.6)
    Super Victor intake (port matched to heads)
    Quick Fuel Tech Custom 750 carb (875 cfm)
    Canton Oil Pan (main girdle)
    JOMAR Rocker girdle
    CSI water pump
    M-6799-A302 (oil restrictor)
    MSD ignition
    6AL Box
    Blaster 3 coil
    MSD start/retard box (set at 25* retard at the start and 4* high end pill)
    ARP (Everything)
    1 5/8 headers (THAT ARE KILLING ME:mad: )
    HOWE aluminum Rad/electric fan
    motor mounts are gone.
    Running front plate/mid-plate.
    Thats pretty much the engine.....:rolleyes:
    Its built for Go...not show:cool:
    http://www.ford.citymaker.com/page/page/1365691.htm
    This always keeps me warm on those cold lonely nights:D
  3. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    WOOOOOOOOOOO WOOOOOOOOOOOOOO
    Yes I did Rick......looking forward to meeting you Earl!
    Is it July yet?
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Good stuff. Maybe a can have a 400hp streetable car. I have got to do something with my little 302 like STOKER. I love to read this stuff.
  5. riporter
    riporter Member
    Charleston S.C.
    Well I'm in awe to say the least, threads like this provide a wealth of invaluable information, and this is not "mock up" stuff...you know it works, it just doesn't get any better than that.
    That said I humbly submit the specs on my build.
    302 block punched 30 over, block was vatted,bored,shotpeened,honed and magnafluxed.
    Eagle 4340 forged crank internally balanced, neutral harmonic balancer and flywheel
    Eagle 4340 h beam connecting rods to Ross domed pistons, clevite bearings
    Comp Cam 224/224 @0.50 lift duration, GVL 500/500
    Canfield heads 192 cc intake runners, chambers milled to 60cc, 10.75 to 1 compression
    Victor jr. intake,hooker 6901 comp headers, all ports milled to match
    Holley ProSystems 780 cfm carb custom matched to setup
    Custom made 4500 stall converter
    C-4 tranny, shift kit, manual valve body, deep sump TCI pan to 9" rear end, Moser locker and 3.55 gears
    Milodon deep sump 8 qt. oil pan and melling high volume pump.
    Stock radiator, 2800 cfm pull through fan with thermostat that keeps engine at 180 degrees under any conditions.
    March serpentine pulley setup.
    100 amp alternator
    MSD 6al ignition sytem to stock distributor
    Holley red electric fuel pump
    Autometer Sport Comp gauges in a Grandmas car interior (yes...I like it like that):D
    Build was made to be respectable at the track on a Sunday night and drive to work or cross country on a Monday morning. Cruises at 2900 rpm at 70 mph.
    Car currently runs 7.9 consistently and could easily pull mid 7's with a taller gear and proper rear/front suspension (it doesn't hook-up very well)
    My sweethaeart is currently having some cosmetic work done to the engine compartment, then its on to the interior and suspension.
    As a kid growing up in the 70's I always had an affinity with nice cars, just couldn't afford my own, in my 20's and 30's I worked and raised 6 kids, last year I bought this car and it's been a love affair ever since.
    I can honestly say with out the information, encouragement and friendship from the folks on this board and MCCI it probably wouldn't have happened.
    __________________
    [​IMG] I put this in the wrong thread to start with, talk about hijackin..sorry Rick Book
  6. mavman
    mavman Member
    Arkansas
    Well...the 414 has not been tried before, at least not by me. Last 2 years I've been running a 14.2:1 357w methanol injected. Best times were mid 6.20's and 110 mph. Grenaded it and had to start over--of course most of the regulars on the boards know that. The 414 is similar to the 357: '74 351w block .060" grouted to the middle of the water holes. Scat 9000 4.000" stroke crank, Eagle 6.250" rods (I have some 6.200" Eagle H beams for sale!!), Mahle forged flat-top pistons for about 13:1 compression. I went with a Scat 9000 crank because Forged would have been nearly $1000 plus these cranks are well made and I've run them before in a 393 that made excellent power (and I was NOT easy on it!!) Would like to have more compression, but couldn't find any pop-ups for under $700. BTW those Mahle Pistons are NICE (and light at just a hair over 400g). Victor Jr heads milled slightly but no other mods, just 11 new valves, 2 new pushrods, had to have one head welded as the rocker stud pad broke off. The heads will most likely be the choke point of the motor, but that's good because with the methanol injector it'll make a ton of torque down low. The cam is a Cam Research solid roller....about 270 duration @ .050" and .700" lift or thereabouts. I haven't seen the cam yet so I can't give exact numbers, but it should be real close to that. Other than that, it's a simple build for bracket racing (nothing fancy) and hopefully this season with the grouted block, I might be able to build heat in the motor quicker. Last season, I'd go through about 3-4 gallons of meth to get it warmed up on a cool day. Probably should have either bought or made a Primer system to idle/start on gas, but I was too cheap & lazy at the time. Might do it this year--haven't decided yet. Either way, I have to get the bugs out of it before I put one on as it's real dependent on throttle blade angle. The throttle body flows 1300 cfm and the intake is an unmolested Victor Jr. A super victor might pick up a little HP, but at the expense of low end, and that's the reason I went with a 414 to begin with. I'm hoping for mid-low 1.30's in the 60' and about the same 1/8 ETs...maybe later on if I can gather up some ca$h, I'll work with another motor and heads to achieve the 750 HP mark and see how that works. Then again, maybe not in this car.
    I'll keep you guys updated on times, etc. Right now, it's on hold...waiting on parts again. As many motors as I've put together, and the one I didn't want to screw up, I broke a ring on the very first piston I put in, so I'm waiting on a ring. Was I pissed at myself? You betchya!:slap:
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    Mavman-
    What about a block heater? Any help? A deep cycle battery and a cheap inverter might save you a few gallons per race.
    Just a thought.
  8. mavman
    mavman Member
    Arkansas
    Should have thought about that last year! No place for the heater to go in now...block is grouted. Should warm up pretty quick now if I use the lean out.
    Thanks though...wish I'd have thought of it before:slap:
  9. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I've thought about that many times recently.
    Seeing as how I don't own a generator at the time... I was thinking about getting a bit more complicated
    I have received a free lawnmower and a free 5 horse motor... Going to make a gas powered battery charger... then was thinking about mounting an inverter on it also so I could charge the battery and keep the block warm at the same time or just one of those seperate....... anyways..... sorry for hijacking
  10. Old Guy
    Old Guy Member
    It's alive, it's alive. Just got the 331 buttoned up in the fairmont, fired on the first crank and only had to set the timing. Trying a 2in phenolic spacer under the carb, on the air gap manifold. Will see if that picks up any top end next race day. What a difference in throttle response compared to the 302 I had in it, will have to see what it does under a load????? A few other things to tend to on it and then it will go out and mavmans, maverick will come in to get ready for the 414ci. Am also doing a c4 for another racer and then the mustang will be the last thing on the agenda for next season, to freshen up. So much to do and so little time, but when you hear that engine fire up and is crisp and awesome sounding, it's all worth it.
  11. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    cool:clap:
    its a great sound makes you sort of know how Dr Frankenstein feels in the movies It's alive:bananaman
  12. riporter
    riporter Member
    Charleston S.C.
    Sounds great Dave...what kinda carb you running?
  13. Andysutt
    Conway Arkansas
    1972 Comet GT
    Congrats!!!!!!!!!!!!
    Does the offer still stand for you to redo a C4 for me?
    If so let me know and I'll see if I can get a rebuild kit for it shortly.
  14. Old Guy
    Old Guy Member
    Have a Holley 750 with the choke horn removed. Plan on putting on an 830 that I have, to see if it may work better. Betting on the 750 being the better choice with my setup.
  15. tim keck
    sharps chapel,Tn
    Ok here's my specs.This was in my 75 4door,now it's in my 70 2door,hope the diffrence in weight puts it on down about 4-6 tenths;
    88 5.0,stock shortblock with b303 cam,ported and shaved(.40)E7 heads w/cobra valvesprings,port matched stealth intake,headman hedders,ARP rod bolts & head studs.150 hp compucar plate,700 holley dp mech secondary w/airhorn shaved off.c4 w/3500 stall,3.55 gears.Nuthin fancy,just good used parts.Only things I bought new were the headers,carb and ARP stuff.:D
