High Beam indicator light
Discussion in 'General Maverick/Comet' started by Pete21136, Apr 29, 2024.
  1. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    Can the instrument cluster be pulled out enough to replace the high beam indicator light bulb without disconnecting the speedometer cable?
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    You can certainly try it, but I would say probably not. I have pulled the cluster so many times that my cable slides off easily after depressing the connector ear.
