Hit the DAMNED water jacket
Discussion in 'General Maverick/Comet' started by scooper77515, Dec 6, 2007.
  1. scooper77515
    Mig is all I have, gotta make it work...:huh:
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    You go Scott!!!!
    Dan
  3. bmcdaniel
    Or stick weld with a nickle rod. And you usually have to preheat the area with a torch.
  4. Dan Starnes
    West Central IL
    Yup, Barry,, that is how I have done it, in fact, the only way I have done it. Never used a tig yet.
    Dan
  5. mavtricks71
    mavtricks71 Member
    i would find another head! thats a problem child!
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I had a crack in the water jacket at the rear of a block. A friend of mine drilled the ends, ground it down and stick welded it with a Nickel rod. Ran that block for years without a leak.
  7. scooper77515
    We will see how this works. If it doesnt...well that would NOT be the first time I messed something up:D
    Going to run a couple of different tests on it to verify the integrity of the material in that area. Not going to just slap it on and pray....
