holes-be-gone
Discussion in 'Cosmetic' started by Racer_X, Apr 29, 2009.
  1. brainsboy
    brainsboy Member
    Tampa
    Body work is done with a Mig welder.
    Stick welding is for thicker metal or for serious penetration like when you work on full frames.
  2. bmcdaniel
    Well, you can if you know what you're doing. That's one of the options we had before mig welders became available. You need to use a stitch weld attachment that cuts the weld current in half and small rods. I always had better luck with that than brazing or oxy-acetelene welding.
    But, yeah, a mig welder is the way to go.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    nothing worse than turning a little hole into a big hole :oops:
  4. 1973Maverick357
    Cookeville TN
    Well how much are wig welders?
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That sounds painful! :biglaugh:
  6. Fat Tony
    Fat Tony Member
    Upstate,SC
    you can buy small migs for a couple hundred dollars that are perfect for doing sheet metal work..
    Check the local pawn shops ;)
