Holley 4160 Base Vac Leak
Discussion in 'Technical' started by jasonwthompson, Jul 8, 2017.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    If the throttle shaft is where it's leaking, then at least a partial rebuild is necessary. Is it also leaking fuel from there? If so, a throttle shaft bushing would have to be installed.
    jasonwthompson likes this.
  3. jasonwthompson
    Carrollton TX
    At the moment it is only a vacuum leak, no fuel. Summit offers Holley carb base replacements, but honestly I would rather replace it than try to repair. Summit has a carb that I was told is based off an older Ford design. I have seen numerous positive reviews on multiple sites about it and it is less than the previous carb I posted above.
    https://www.summitracing.com/parts/sum-m08600vs
  4. Krazy Comet
    Crazy Larry and jasonwthompson like this.
  5. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Are you certain it's the base and not the gasket? I would be with Krazy and just replace the base if the carb is overall performing well. - Matt
  6. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    My 4160 has developed a slight hesitation. What is yours doing? How did you determine where the vacuum leak was coming from?
  7. Hotrock
    Munroe Falls, Ohio
    The Summit carburetor is a great buy. I ran one for several years and highly recommend it should you decide to replace rather than repair.
  8. Krazy Comet
    Slight hesitation is rarely caused by a vac leak...
    Generally misadjusted pump shot linkage or maybe a hardened pump diaphragm is the culprit... Late ignition timing can also cause a issue...
    jasonwthompson and Crazy Larry like this.
  9. jasonwthompson
    Carrollton TX
    You can get a hesitation problem with a vacuum leak. In my particular case it became increasingly more difficult for the car to hold a steady idle, hard starting, choppy idle in gear, will not idle in gear, extreme hesitation on acceleration. In the past I knew this engine had a manifold vacuum of about 20lbs. Once the symptoms appeared, manifold vacuum was between 10 - 15. To find the potential source of the leak, I disconnected and plugged all vacuum connections to the manifold and carb. While the engine is running I sprayed carb cleaner around the manifold and carburetor. It will be obvious when you hit the right spot as the engine will slightly rev up. In my case, part of the leak was from the secondary throttle shaft (it is a 4 barrel carb). After replacing the base plate it no longer leaks through the throttle shaft but there was still a leak. So I replaced the carb with the Summit one listed above and put the Holley on the shelf for a later rebuild.
  10. jasonwthompson
    Carrollton TX
    Thanks Hotrock, you were right it is a great buy and so far runs great. Throttle response is awesome right out of the box.
  11. HadaGrabberonce
    Talcott WV
    Good tips. Sounds like my problem may be the diaphragm. Ran fine last fall but problem developed over the winter.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    A bad vacuum advance cannister on the distributor can cause a part-throttle hesitation. Make sure yours doesn't have a bad diaphragm.
  13. HadaGrabberonce
    Talcott WV
    O.K. Already bought the diaphragm for the Holley so I will try that first. The car still has the original distributor so it is possible the vacuum advance could need replaced also.
  14. jasonwthompson
    Carrollton TX
    You can easily test it by disconnecting and plugging the vacuum line going to the distributor.
  15. HadaGrabberonce
    Talcott WV
    Thanks Tom. The pump diaphragm was the problem. No hesitation now. $6.99 at Advance.
    Krazy Comet likes this.
