holley carb help
Discussion in 'Technical' started by runeking40, Jul 10, 2010.
  1. blugene
    Looking at the pics again just now. Your carb linkage is not the same as mine. You might want to get some more info from other sources before doing anything. If you look at my pic, my kick down is connected to the bottom where yours does not have anything. My carb is a double pumper designed for a Ford. I am thinking that yours is a Ford also but is made just for a rod. I would call the guys at the link I gave and see if they can provide some answers. They might tell you to change the throttle shaft or something if you are gonna use that carb.
  2. blugene
    Dang! I missed that also. Your carb does not have the ball stud for the carb cable. It requires a certain size as there are several size ball studs. Our cars all have the same size. Do you have the origional carb to match the ball stud with?
    Edit: The answer is yes provided you get the ball stud.
  3. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    no i mean i have my inline 6 carb but i have never had a 4 barrel carb stud i do have other 2 barrel 302 carbs how do i get one
    also what do you mean by carb cable is that the throttle?
  4. blugene
    Yes, throttle cable.
    Did you change from a 6 to 8?
    Those 2 barrel carbs have the stud size for comparisson, unless you check and see that one will unbolt, I doubt it. You can buy the stud but you need to know what size. That's where the comparrison comes in handy.
  5. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    yes i changed from a 6 to an 8
    the 2 barrels are not off a maverick through did you say the maverick has a specific ball size
  6. blugene
    No, Ford has the specific size.
    All I ever read about swaping to an 8 is that the cable will not work. Looking at my 75 with a 6 I see that it will not work.
  7. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    but other than that i can use an original throttle cable and still use the lokar kickdown
  8. blugene
    Yes. Again, you need a V8 throttle cable with the bracket.
  9. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    what v8 bracket are you talking about?
  10. blugene
    The throttle cable has a bracket to hold it at the back of the carb. Give me a second and I will show you one. I sold mine when I bought my set up. On my pic you can see where the two cables are bolted to at the back of the carb.
  11. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    the throttle cable has the bracket on it?
  12. blugene
    See if you can make it out. If you notice, there is a red piece. That piece is used on an after market V8 intake. Otherwise the bracket bolts to the factory 2 barrel intake intake. This is exactly what you need if you want to use a factory style throttle cable. If you do not have the cable then check the price and see if you want to get the Lokar. I am sure some one here has the factory set up..hopefuly.
  13. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    i have a factory 4 barrel intake
  14. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    so my inline 6 throttle cable wont work and my only option is to get one like you have in the picture or i can buy a throttle off of lokar
  15. blugene
    Now you got me. I don't know if the bracket will work because it is desigend for the 2 barrel. When I bought my 4 barrel Performer intake it came with that adaptor plate to be able to use the factory bracket. Our cars did not come with a 4 barrel so my guess is that it will not bolt up, but that is something I have not come across, sorry.
    It may be that the fastest and simplest solution is to go to the Lokar cables and bracket. Hopefuly someone that has done this will chime in for you.
