Holley in tank fuel pump
Discussion in 'General Maverick/Comet' started by William623, Feb 4, 2022.
  1. William623
    Orlando
    1973 ford maverick grabber
  2. bmcdaniel
    I've been considering that as I have a '70 Mustang tank in mine with my FiTech. Would free up some room in the engine compartment if I remove the FiTech fuel command center.
    William623 likes this.
  3. 71gold
    I Love my...12-305...I used the...1969 Mustang- 20 gallon tank float...:drive:...:chirp:
    pics. are it outside and inside the tank.
  4. bmcdaniel
    I have a MeterMatch module on my fuel gauge to dial in the calibration. I guess you could run any arm and dial it in with that. I see they cost $75 now, back when I bought mine they were $50.
    https://www.technoversions.com/MeterMatch.html
  5. Shorty
    Shorty Member
    Lafayette, In
    I'll vouch for MeterMatch as well. I trust my fuel gauge now! I talked to the company and they are good people.
    Bruce
    71gold likes this.
  6. 71gold
    My Dakota Digital fuel gauge is also programable. it reads from...0-99%.
  7. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Looks good, and the Hydra Mat is very effective.
  8. William623
    Orlando
    Thanks guys! I went ahead and pulled the trigger and got the holley in tank pump. I will be running a new Spectra f30 19 gallon tank with it. I likely wont add a return line. I talked to the holley tech line and this pump will adjust pressure based off need so there is no need for one. Soon my car will be running the sniper system.
    JosephBrand, bmcdaniel and mojo like this.
  9. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    So this is both the pump and sending unit? Doesn't it need a baffle around the pump to prevent starvation on launch, stop and turns?
  10. William623
    Orlando
    Correct this is the pump and the sending unit. It has a hydro mat which acts as a primary filter and apparently helps with starvation as well.
    jasonwthompson and 71gold like this.
  11. jasonwthompson
    Carrollton TX
    Excellent, looking forward to hear more feedback once you get it installed.
    mojo likes this.
  12. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    keep us updated thinking of doing the same and do a sniper single
    barrel on my 250 l6
  13. 71gold
    a friend of mine just put a sniper small bore 2 bbl. on his 72 Datsun 4 cyl. he said it runs great.
    JosephBrand likes this.
  14. William623
    Orlando
    Installed the sniper and the fuel pump. They work great! The pump is a royal pain to get into the fuel tank. Many choice words were spoken. Now I have to figure out why the gas gauge is reading over full with 5 gallons of gas in the tank o_O
  15. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    there are different arms for different size tanks. but it did go in well and no leaks because that rocks. also if using factory harness check all wiring and grounds.
