Holley in tank fuel pump
Discussion in 'General Maverick/Comet' started by William623, Feb 4, 2022.
  1. William623
    Orlando
    1973 ford maverick grabber
    I used the correct arm. The 20 gallon arm using the spectra f30 tank Which is 19 gallons so it shouldn’t read that level with so little gas. But it was struggle to get in but it works great.
  2. William623
    Orlando
    I’m going to recheck everything but wiring should be sound along with ground.
  3. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    weird let us know the solution when you figure it out. I plan to redo all my wiring with a ron francis kit and doing the single barrel sniper on my 250 l6. glad to know I can use this sending unit.
  4. William623
    Orlando
    Talked with Holley tech support and was able to get the Ohms for the unit. Full should be 4-8, empty around 75. No took apart the unit again and was able to find a small issue with one of the grounds. Now it works perfectly! Drove the car 10 miles no issues at all. The gas gauge reads just over 3/4 of the way full on a full tank. I am using the 19 gallon tank and a 20 gallon arm so I can live with the slight discrepancy. Overall I like the combo. The Sniper is very responsive and isn’t a hard instal at all. Highly recommend it so far.
    JosephBrand and mojo like this.
  5. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    great to hear. when you get a chance when your tank is full take a pic of the gas gauge. wondering if since I am going aftermarket gauges I can get it to read correctly
  6. William623
    Orlando
    Full gas gauge reads 3/4 full as previously stated..
  7. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    cool. sorry I thought you had said it reads a little over 3/4 so I thought there may be a way to adjust it. thanks for all the helpful information though. it helps me know I can use a intank pump for when I go with 1 barrel efi
  8. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    You can calibrate the gauge with a simple potentiometer or "trim pot" if you like. There are a 100 articles and discussions on it out there, but here's one: https://www.ffcars.com/threads/calibrating-fuel-gauge.614282/
    CA189HJN likes this.
  9. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Maybe the 16 gallon arm instead of the 20?
  10. William623
    Orlando
    Possibly, but that thing is such a pain in the butt to get in and out plus dropping the tank it’s not worth it right now. Worst case I will buy a calibration unit for it.
    JosephBrand likes this.
  11. Kel
    Kel Member
    California
    72 Maverick
    And this is with your stock tank with the sending unit that comes out the side behind the left rear tire?
  12. 71gold
    yes...
  13. 71gold
    I installed mine w/tank in the car.
  14. Kel
    Kel Member
    California
    72 Maverick
    Do you happen to remember the part# that you used 71gold?
  15. 71gold
    pg# 1 post #3.
