Hood Scoop vs. Cowl Induction
Discussion in 'Cosmetic' started by David74maverick, Sep 13, 2013.
  1. Authetics; Hood Scoop
    16 vote(s)
    45.7%
  2. Authetics; Cowl Induction
    4 vote(s)
    11.4%
  3. Functionality; Hood Scoop
    10 vote(s)
    28.6%
  4. Functionality; Cowl Induction
    13 vote(s)
    37.1%
Multiple votes are allowed.
  1. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    yeah I'll probably go with a scoop, easier... otherwise I'll probably try to over engineer it and never get it done... I would probably try to make a all out race hood, with cowl induction that dives almost halfway down and behind the radiator...
  2. David74maverick
    Arizona
    I've been working on a steel scoop like the fiberglass one that was one it. Now I'm trying to figure out how I want to finish the front edge. Rounding it? fold it over like the back of the door than round it? weld a strip of metal at ~45% than round/smooth out the weld? I've been debating for awhile and I'm kind of leaning toward the rounding or weld and round... here is what I got so far,
    Would appreciate some input. Thanks
  3. CaptainComet
    Really nice work!
    I almost want to say leave it "as is", but it probably does need to have some visual thickness for the front uprights ... maybe 1/2" on each side, but I like the crisp edge line. I am thinking a bit like the Cobra Jet scoops, where the inner part of the opening was a vertical filler.
  4. olerodder
    olerodder Member
    NorCal
    As was said, really very nice workmanship............I like it!
    Personally, I'd round it. I think it would make look and feel finished....IMHO
  5. darren
    OK that looks really good!! When I read you were making one out of steel I thought oh no here we go! LOL. Not what I expected. Nice work.
  6. CaptainComet
    When I said leave it "as is", I hope nobody was assuming I meant raw metal and unfinished bodywork. ;) I was thinking the basic shape on it is pretty darned good.
  7. David74maverick
    Arizona
    that is where I'm leaning... roll all the front edges and where the two angles meets in the center give it a small ridge line...
  8. David74maverick
    Arizona
    Trying to figure out at what point do I stop hammering and use bondo... trying to smooth out the rounded top-to-side transitions and the top ridge line that runs the length of it.
  9. olerodder
    olerodder Member
    NorCal
    When you feel comfortable with the looks..................kind of like when do I stop trying to get more HP out of a motor!?
  10. David74maverick
    Arizona
    It's close but the top-to-side hammered transitions are not perfectly smooth and consistent like I want it (radius seems the same but the elevation isn't) but I'm getting to the point to where I'm afraid of "overworking" it and just jacking it up.
  11. David74maverick
    Arizona
    Rounded the front edge, the issue I'm having with the top to passenger side edge is only a elevation change of about a 1/8th inch if that... I'll probably try to work it a little more, here is a couple pictures of the front rolled edge.
    If I went by the work it till your satisfied, well I probably wont be satisfied till it looks like it's pressure formed and take a lot more time than what I've already invested especially with the tools I'm working with so I will probably reach the "I'm sick of working on this so I'm gonna use bondo" point pretty soon there.
