Hood
Discussion in 'New Members Forum' started by BEAVERMAV, Nov 27, 2016.
Tags:
  1. BEAVERMAV
    BEAVERMAV Member
    Beaver Falls, PA
    1974 Ford Maverick, 4 door, 250 6cyl.
    I need to replace my 1974 4 door maverick hood. Are all stock hoods the same 2dr or 4dr? Plus I have a bent driverside hinge, need replacement or are there hood lifts that won't require a hood prop?
  2. yellow75
    Tillamook Oregon
    All hoods are the same on 2 door and 4 door Mavericks besides the scooped Grabber hood and even it would fit. There are no hinges made to eliminate the the hood prop rod but some people have made their hoods stay open by adding a gas shock like on the tail gate lift windows and hatch back cars and if I recall some has also modded their car by adding springs from other cars
    Maverick Dude likes this.
  3. mav1970
    I have a hood from a 75 on my 69.5 - fit like a glove :thumbs2:
  4. BEAVERMAV
    BEAVERMAV Member
    Beaver Falls, PA
    thank you
  5. bmcdaniel
    The only difference I've seen between hoods is later ones have a flat portion in the support structure to accommodate an air conditioning compressor.
