hooker 6208s may be on the way
Discussion in 'General Maverick/Comet' started by eddie1975, Sep 17, 2006.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    No. Never did the W thing. I had a C.
    I did post some pics once, of an install, that I had saved on the PC in case I ever decided to do it.
    I am pretty sure I lifted the pics from this site.
    The guy did a pretty good write up and shows everything that needs clearance.
    Gotta trim the engine mounts a little, grind a nub off the steering box, and grind the passenger side frame rail. I think he may have even notched and boxed the section of rail.
    Check around.
    He posted the pics, probably years ago now, and I rehashed them in a thread... so they are here.
    If I run across them, I'll point them out. It's getting late for me now though.
    Dave
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    there was a post a LONG while back about them , where he(bossmav) did mods to the car not the tubes, i seen his car the other week and he showed me a couple things , like the passenger side frame...thanks dave i thought it was a good deal for these....i wouldnt have cared if you would have got them cause i know there goin to a good home i was not goin to spend more than 350 for them and i got them for 348.99 plus 30 for shipping , i firgure if i go much more i might as well buy i new set from summit....but i won and they look brand new, i was thinking after i get them installed sent them to JET HOT or a place like that to get them nice and pretty:D
  3. scooper77515
    Might help with my spark plug issue on my GT40P heads... :rolleyes:
  4. eddie1975
    Martinsburg, WV
    sold
    i guess it could, if you were to make the sections in the right area, im not sure with the gt40Ps , are the spark plugs in a differnt angle or something?
    eddie
  5. scooper77515
    Spark plugs are straight out, facing the center of the tube, closest to the tube. Almost "hemi-ish" (but only on the driver side, passenger side they miss the header completely). Main problem is on the driver side, especially #s 6&7 plugs. They are close enough to touch the pipes even with HEI 90 degree boots, and a 1/4" spacer, AND shorty header plugs.
  6. eddie1975
    Martinsburg, WV
    sold
    yeah i thought ive herd something like that , didnt know the specs though , i bet spark plug changes are fun:slap: , prolly about as much fun as it will be for me with my windsor, i dont know if anyone here has tried 6208 with gt40p heads, cause i know the tube 1 , 2 and 5 ,6 go straight done at first almost prolly be pretty close not sure thought with 1/4 spacer, i firgure these 1 3/4 might be kinda over kill , cause im not turning over 6000, but i dont think they would hurt to much, im sure it does alot better than 1 1/2, and if i ever deiced to go big and better , which who doesnt want to :D
  7. scooper77515
  8. eddie1975
    Martinsburg, WV
    sold
    holy crap , that looks like a fun day to change plugs , that is crazy , is there an exact reason for that?
  9. scooper77515
    After doing it a few times, I got it down to a 45 minute job. Have to pull the header bolts half out and use a cut up socket (with a notch cut out of the side) to get the plugs out. Funny thing is I spent an afternoon making this socket, then about a year later, saw them advertised in Hot Rod, so apparently this is not an uncommon issue.
  10. rayzorsharp
    Too bad you didn't get yours patented 1st :huh:
  11. ratio411
    ratio411 Member
    Pensacola
    If you made your tubes into 4 individual pieces on that side, you could just unbolt the tubes that give you trouble and swing them over to the side.
    Before I got too involved doing it though, I would make sure there is somewhere for the tube to go, otherwise it is a waste.
  12. scooper77515
    Ratio, that is what I was thinking...
  13. ratio411
    ratio411 Member
    Pensacola
    Idea:
    Cut the header flange between all the pipes for best clearance.
    Cut the offending tubes off at the first possible straight run.
    However many tubes you cut, get the same number of i/d to i/d adapter pipes.
    Weld the slip on adapter pipe to one side, keep the other side 'slip fit'.
    Reinstall headers.
    Now you just unbolt the 2 bolts only on the pipes in the way, then slip them up out of the connector.
    Replace the tubes when done with the plugs.
    Gasket never moves, no pipes move that don't actually need to, and the pipe is sectioned short enough to just pull it straight up and out for a moment.
    Dave
    Edit: Weld the slip pipe section on 'downstream'. That is how the manufacturers do it. Probably have better flow and no leaks that way.
    Welded 'upstream', the exhaust will be pushing against the open side of the pipe.
  14. scooper77515
    You know, since the beginning of this thread, that is exactly what I was thinking of doing (what Ratio said). I just wasn't sure that I could cut the flanges away and just have the two bolts per hole hold it on well enough. If it will, I will do this the next time I take out the engine and/or the header. Then I could swap, or repair any one plug I might need to without messing with the entire header.
    What do you think, maybe 1" of slip-over, or should I do more overlap?
    I could also put in a spacer on just the two cylinders that need it...
  15. eddie1975
    Martinsburg, WV
    sold
    i would say 1 inch should be good maybe 1 1/2:yup:
