Hooker 6901 header ground clearance
Discussion in 'General Maverick/Comet' started by Slk70, Apr 19, 2007.
How low are 6901's
Poll closed May 10, 2007.
  1. Are 6901's too low for avg. unlowered car (sleeper)
    1 vote(s)
    7.1%
  2. Are they not generally a problem for avg. unlowered car
    10 vote(s)
    71.4%
  3. Moderatley lowered, are they annoying and you wish you had something else
    3 vote(s)
    21.4%
  4. In hinesite, would you choose a shorty header over these
    0 vote(s)
    0.0%
  1. Slk70
    Slk70 Member
    Los Angeles
    Ratio, I am not challenging your theory, but all I learned since growing up is cooler means more power. Before these headers (ceramic) came out, we were doing things with the cooling system to keep the motor cool, so it would perform better.
    Here's one for you... Have you ever driven a car during the day (warm day), then driven that same car at night. There's a night and day difference in performance. Why... It's much cooler at night. A cooler car will alwas run better.
  2. bmcdaniel
    All the theory aside, I didn't get my headers coated because of a performance advantage. I simply did it to make them last longer and look better, the coating definitely did that. And maybe I'll find out next winter if there's a clearance problem. I doubt there will be.
  3. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Do you have a part number for us?
    Also what size tubes are they (sorry if I missed it if you`ve already said)?
  4. Slk70
    Slk70 Member
    Los Angeles
    I have heard from a few that the Hedmans actually hang a little lower than the Hookers. I went with the Hoolers based on responses.
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Well.................. nevermind :rolleyes:
    Mike, they are 1' 5/8" primaries.
  6. M.A.V.
    Macon,Georgia
    Thanks John :)
  7. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    headman did not show just 67 it showed 65 up
  8. Slk70
    Slk70 Member
    Los Angeles
    I also forgot to add that some of the tubes needed to be dinged with the Hedmans, the Hookers dropped right in.
    When you call and talk to Jet Hot, they even tell you they sell more Hookers for the Mav because they are proven to fit better than Hedmans.
  9. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    who cares....
    now thats funny right there :rofl:
  10. Slk70
    Slk70 Member
    Los Angeles
    Yeah, I know. I should have just read it a bit the hand. Sometimes it's hard though. I will probably catch it for that.
  11. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I never had to ding any brand LT header.
    The Tri-Ys are a different story though.
    I don't think the engine 'must' be raised for any LT header either.
    But you have to get the car high enough in the air to be able to skip raising the engine.
    I would just rather raise the engine and have the car at a sane height than to jack it up crazy high just to get the headers in. Doing it this way makes it easier to lean over the fender and secure the header for lowering.
    Just my thoughts on the engine raising issue. Only takes one bolt per header, then falls right back into place.:huh:
  12. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    me neither Lonnie, I just figured it was a pointless comment...at this point :p
  13. Slk70
    Slk70 Member
    Los Angeles
    This is what I've heard asking around. Not confirming it to be accurate info at all.
  14. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I understand :D
    Its just funny!
  15. ratio411
    ratio411 Member
    Pensacola
    Raising the engine is NOT a must.
    However, the car must be jacked up much higher that way.
    Just a heads up.
    It will work.
