Hooker 6901 Install
Discussion in 'Technical' started by chachie, Dec 7, 2009.
  1. WesCoaster71
    WesCoaster71 Member
    california
    1971 ford maverick A.O.D trans 302 5.0 cu
    hmmm somthing to think about thanks bryant the bolts i got were 7/16ths and 2in long idk if i got the right ones yet im still at work but ill find out when im home i have a aod trans
  2. Bryant
    you could be right on the bolts. i just cant remember. ive been working on chevys lately and they seem to do every bolt one size smaller than ford. so its hard to remember who uses what. i do think fords trans bolt heads use a 5/8s bolt head which should be a 7/16s bolt. i also seem to remember that the two top bolts are shorter than the 4 side bolts.
  3. WesCoaster71
    WesCoaster71 Member
    california
    Thanks for the info i tend to be a masiah when it comes to this stuff i gues i have luck on my side or someones watchin over me but i did get two shorter ones just in case.... To see where i was with my eyeballin Ill let you know when im home just to freshin your memory
  4. Shorty
    Shorty Member
    Lafayette, In
    I just bought 7/16" x 14 - Grade 8 bolts for my manual transmission bell housing installation. I bought 1 1/2" for the top bolts, 2" for two of the side bolts and 2 1/2" long for where my clutch slave cylinder bracket will mount.
    Bruce
  5. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    whats the power steering drop down bracket part number? Im going to make them fit with the ps and column shifter
