Hooker Headers AFR Heads
Discussion in 'Technical' started by bhellickson, Jun 19, 2015.
  1. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    The hooker 6208s are a great header even though you to modify the body just a little,& they will support 600hp on a stroked 351w.
  2. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    How much room is there between your passenger side header and the strut tower at the closest point? Does the engine torque over far enough to touch?
  3. bhellickson
    bhellickson Member
    S. California
    1970 x2 71x2
    I threw the hookers into the trash and never looked back. Junk junk junk. Went with a set of Sanderson shortys that fit perfectly. Since the angle on the AFR heads is different than stock there was no room for the hookers at all. Let me also mention the difference in quality between the Sandersons and the hookers was day and night. I called Sanderson told them what I was doing and 3 days later had my headers. No fitment issues, no having to jack the engine up just slipped right in.
  4. layne
    layne Member
    Orlando, Florida
    70 Maverick, 70 Mach 1, 70 Cougar Eliminator
    Hooker 6901 fit perfect on my car, no modifications at all.
  5. bhellickson
    bhellickson Member
    S. California
    1970 x2 71x2
    I am guessing stock heads that let your hookers fit?
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    It seems no 2 sets of 6901's look exactly alike. I have AFR heads and my exhaust flanges partially blocked my exhaust ports on the sides, requiring a session with the die grinder. Another forum member has the same heads and his 6901's didn't require any modification. The other fitment issue with the Hookers is that they were designed for multiple chassis applications vs. being Maverick/Comet specific. That is why there are bends that seem unnecessary and other areas that afford little to no clearance.
  7. tody
    tody Member
    cologne, germany
    i went through major hammering while trying to get the driver's side installed.
    afr 185 heads on a 302 block as well...
  8. Cruzin Illusion
    1972 Grabber
    I would assume the difference in heads are the height of the exhaust ports. I have never set a stock set of heads next to an aftermarket performance head.
  9. bmcdaniel
    Size-wise I doubt the AFRs are that much different than the Edelbrock RPMs I'm running with 6901s now. The only interference I had was with the steering linkage on the driver's' side hitting the bottom of one tube. After awhile it clearance itself. LOL
    Years ago I had AFR 185s on my car but with an old set of Blackjack headers. Those puppies could go in from the top but they had very tight bends right off the header flange, couldn't be good. And it seems the Hookers weigh about 50% more, much heftier flanges and tubes.
  10. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    My headmans fit perfect
  11. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Is there any issue with the AFR heads vs stock Ford heads when bolting on headers?
    MD
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Perhaps. Read my personal issues with Hooker 6901's on multiple threads.
    If you are using 165's or 185's, the only issues I am aware of is exhaust port alignment with the header flanges. Some people have issues, some don't. I had to open my header flanges up slightly on the sides. If you move up to the AFR 190's, the fitment may become an issue due to the fact that the exhaust ports are raised slightly. Again, this may not be a significant issue.
  13. Maverick Dude
    Can this all be solved with Doug Thorley shorties?
    MD
  14. Maverick Dude
    Tried the Sanderson website but couldn't find a reference to Mavs or Comets. Do you have the model number? Thanks.
    MD
  15. Maverick Dude
    Sanderson FF3GTS and FF6 apparently will fit 302's in smaller Ford's but no mention of the Maverick specifically. Might it been one of these?
    MD
