Horn Help
Discussion in 'Technical' started by 302yellow72, Aug 1, 2021.
Tags:
  1. 302yellow72
    302yellow72 Member
    Poulsbo WA
    1972 Maverick 302
    My horn is dead. I’ve verified everything else in the system works. Can’t even get the horn to work junketing it to the battery. Is there a source for a factory horn? I looked around and all I could find were generic replacements and sets of horns for other fords. I think mine is an aftermarket replacement but I don’t know for sure. Anyone have a horn for sale?
  2. wiesguy
    wiesguy Member
    Scottsville, Ky
    74 Comet GT V8 74 Comet I6 2Dr
    Not Ford, Delco is genuine GM.
  3. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    He's right. That's not the original horn for your car anyway.
  4. Krazy Comet
    Dismal Swamp
    Mostly a horn is a horn(though there are high & low notes). Single setups usually have a high note. Get one or a pair from a late model in junk yard.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Originally the Comet only had a Lo horn mounted under the hood next to the wiper wash tank. I added a Hi horn using a C7ZZ-13832-H and moved them to the grill side of the radiator support. The bracket looked like the factory Lo version and it sounds less anemic now.
    Krazy Comet likes this.
  6. mojo
    I agree "A horn is a horn"! I add a 2nd. horn installed behind valance, put horns on a relay. Sounds like a normal car now.
    Add a horn and move on...
    Shorty and Krazy Comet like this.
  7. 302yellow72
    302yellow72 Member
    Poulsbo WA
    1972 Maverick 302
    I decided to go with a 71-73 Mustang right side horn.
    mojo likes this.
  8. 71gold
    I have a set from a Crown Vic.
