horn problems
Discussion in 'Technical' started by russellgaspard, Jul 3, 2015.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    My horn stopped working and when I press it the horn sparks at the steering wheel. I checked and changed the fuses. Does anyone know what's going on?
  2. Krazy Comet
    Hey man what are you complaining about?? Tomorrow is the 4th of July, sparks are good [​IMG]
    Seriously you likely have a shorted power wire to horn or maybe the horn is shorted... Pull connector from horn, if sparks stop the horn is shorted, if not there is a wiring issue..
  3. Craig Selvey
    If you have an aftermarket steering wheel.....then that is your problem. They are not none for really good horn switches.
  4. russellgaspard
    united states
    What do you mean?
  5. Krazy Comet
    Aftermarket generally means a custom, modified or general replacement part(in this case steering wheel), that's not same as or maybe not constructed to factory original specs...
  6. Shorty
    Shorty Member
    Lafayette, In
